Robert Lussier and Jia Hao Wu
Development of a Data Exchange Protocol between EMME/2 and ArcInfo
Abstract
Sharing spatial information between a transportation planning software (like EMME/2) and a GIS (like ArcInfo) is a complicated task, both in terms of data structure and informational needs.
INRO Consultants established guidelines to standardize the creation of a transportation planning coverage and developed a set of tools to transfer information between EMME/2 and ArcInfo.
In this paper, we identify the motivation for the development of a data exchange procedure between ArcInfo and EMME/2. Then we identify the corresponding data items in ArcInfo and EMME/2, discuss the communication process for exchanging data and computed results between the two systems, and develop a user-friendly interface to realize the data exchange. As a concrete example, we present a prototype of the system for the EMME/2 road and transit network, which can be used to display the attributes and results obtained in EMME/2. Future developments and possible applications of this system are discussed as well.
A) Motivation
GIS software packages are used mainly as a tool for managing spatial information and performing associated computations. They have good database management features and boast effective manipulation and representation of spatial data.
Unfortunately, for the purposes of transportation planning, they offer a limited set of tools. The transportation planner deals with an aggregate representation of networks (current and future) and wants to compare different scenarios in order to make a recommendation. This information cannot be obtained from a typical GIS. To assist the planner in more complex and specific tasks other software packages, like EMME/2, offer a working environment that incorporates some spatial data manipulation features and, above all, provide strong network assignment and demand modeling capabilities.
Since much effort is usually invested in the creation of databases (be it at the city, county, or state levels) to manage spatial information within a GIS, it would be beneficial to be able to share data and analysis results in order to expand the database.
It is costly to maintain different databases for different applications in different departments. Therefore, the goal is to integrate these databases into a common multi-purpose database. Our efforts serve as a contribution towards the compatibility of spatial information, as requested by the GIS community.
In this paper we consider ArcInfo as the GIS software package, and EMME/2 as the transportation planning software package.
B) Objectives
The objectives of this project are:
C) Data models of ArcInfo and EMME/2
C1) EMME/2 road and transit network data model
The EMME/2 data model is divided into three main categories:
Each of these elements may have attributes, which are subdivided into three types:
This network data set forms a scenario, and an EMME/2 data bank may contain several scenarios. For example, one scenario may correspond to the base year, while others may represent different network variants envisaged for future years.
EMME/2 stores information in a "vertically" structured data format (each element attribute, such as link length, is stored in a vector). Compared to a "horizontal" structure, where a row in a table contains all the attributes of an element, a "vertical" one makes efficient use of the available computer memory space and also drastically reduces the number of disk accesses required to quickly and selectively access the EMME/2 data bank.
C2) ArcInfo network data model
ArcInfo supports many data models (coverage, grid, triangulated irregular network, CAD, etc.) to represent geographic information. A coverage is for vector data, and supports georelational models, that is, it contains both the spatial and attribute data for geographic features. The feature classes, used in the coverage to store geographic features, are:
ArcInfo stores coordinates only for points, arcs, and nodes, and uses topological relationships for defining networks and polygons. Here are the three topological concepts used to define features:
Networks and polygons form the framework for defining the two other feature classes:
To represent transportation networks, ArcInfo uses the previous feature classes as the basis of the NETWORK data model. The model consists of: Since the transit system uses some of the arcs of the transportation network and is defined by different data attributes, it is best represented by dynamic segmentation (route-system and events). It is composed of the following elements:
C3) Relationship between data elements and features contained in both models
The following table contains general object descriptions found in a transportation planning infrastructure, and the corresponding element in both software packages:
ObjectsArcInfo itemsEMME/2 items
streetroute-
street sectionsection-
directed street sectionarclink
intersectionnodenode
traffic lightnodenode
transit linerouteline
transit sectionsection
(within a route)
segment
(within a line)
transit stopspoint event, nodenode
regionregionzone, group, ensemble
TAZ (traffic analysis zone)polygonzone
Origin and Destinationnode, centercentroid
O-D matrix-matrix
supply centernodecentroid
demand centernodecentroid
turnsturn (arc-node-arc)turn (at_node-from_node-to_node)
arc-to-arc barrierarc selection setturn penalties
drawingpolyline, patternsannotation, demarcations
textannotationannotation
C4) Differences and "inconsistencies" between the two data models
ArcInfoEMME/2
-arcs can be bidirectional (with directional attributes)-links are unidirectional (represent flow of traffic)
-each arc can be composed of up to 500 vertices, including from-node and to-node-each link is composed of an i-node (from-node) and a j-node (to-node)
-a node is created by the CLEAN command when two arcs crossover (polygon topology)-links can pass one over another
-bus stops can be stored as point events which are not necessarily represented by nodes at the arc-node level -bus stops must be represented by a node
-all feature attributes are stored in a relational-like data base ("horizontal" structure) that is managed by the INFO information manager (or other external relational data base managers)-element attributes are stored in a "vertical" structure
-tables are mostly user-defined depending of the user applications and data needs-many of the attributes are already defined (standard attributes)
D) The communication process
Although it seems natural to consider a direct communication process between an ArcInfo workspace (Master GIS) and an EMME/2 data bank, there are several difficulties involved. For example, given an ArcInfo workspace where there are a road network and a transit network, we still have to define traffic zones and decide on a certain aggregation of the network representation for some specific applications. This can only be carried out by the transportation planners and not by an automatic process. In order to establish an automatic process that can exchange information between the two software packages, we decided to establish an EMME/2 coverage in ArcInfo with a "one-to-one" relationship with the EMME/2 network elements. The communication paths are shown in Figure 1. Note that there is no specific sequence in this figure.
General components involved in the joint utilization of ArcInfo and EMME/2
Figure 1 - General components involved in the joint utilization of ArcInfo and EMME/2
The ArcInfo workspace is considered to be a database created independently by ArcInfo users from their organizational point of view (policy, MIS standards, etc.). Therefore, one may expect a variety of data definitions and data contents stored in this database. The representation of real-world entities may vary in detail.
The EMME/2 data bank is an aggregate representation of the transportation infrastructure, the economic activities and the socio-economic characteristics of the urban area studied.
The EMME/2 coverage follows the EMME/2 network representation. This implies:
The goal of the communication process is to integrate the two databases in a standard way. There are four cases to consider:
The modeling process represents the transformation of the user network in the master GIS into the EMME/2 coverage. This can be complex or simple depending on the design of the database. In order to create the EMME/2 coverage from an existing master GIS, the planner has to take a road network coverage and convert it into an aggregate representation by removing unnecessary details, merging some arcs together and reevaluating attributes. Also, if the transportation network includes a transit network, the planner has to take the route-system representing transit lines and split underlying arcs at bus stops to create a node. This process must include a procedure to keep the correspondence between the user network and the base network of the EMME/2 coverage. The modeling process is specific to the organization where it is implemented.
E) Data structure of the EMME/2 coverage
Entity-Relationship Diagram
Figure 2 - Entity-Relationship Diagram
The EMME2.AAT table stores information related to the arcs of the EMME/2 coverage, and its definition follows the NETWORK data model of ArcInfo. This implies that, since one arc may be travelled in two directions, each attribute of the arc is represented by a from-to attribute and a to-from attribute. The first six fields of this table are standard and contain internal information. They are created by ArcInfo when building the arc-node topology. The EMME2-ID field is used to store a unique arc identifier number in order to maintain the correspondence between an arc in ArcInfo and a link in EMME/2. If the EMME/2 coverage is derived from an existing user coverage in the master GIS, then this number is already present and can be directly exported to an extra attribute in the EMME/2 data bank. However, if the EMME/2 coverage is derived from an EMME/2 network, this identifier must be evaluated in EMME/2. Since a two-way street, represented by two links in EMME/2, is represented by only one arc in ArcInfo, one needs to compute the identifier based on the internal link index of the EMME/2 data bank, and keep the result in an extra attribute (by default @arcid). The EMME2-ID is computed as follows:
This is easily done with an EMME/2 macro. This distinction is required in order to establish which information is related to the from-to direction and which to the to-from direction. The table definition of EMME2.AAT can be found in Appendix A.
The EMME2.NAT table stores information related to nodes. The first two fields of this table contain internal information, also created when building the arc-node topology, and are maintained by ArcInfo. The EMME2-ID field is used to store the EMME/2 node number. Again, if the EMME/2 coverage is derived from an existing user coverage in the master GIS, then this number is already present, and can be directly used as the node identifier in EMME/2. However, if the EMME/2 coverage is derived from an EMME/2 network, this identifier should be computed using the relation between FNODE# and TNODE# fields of the EMME2.AAT table, and the EMME2# field of the EMME2.NAT table. Since the INODE and JNODE fields of the EMME2.AAT table contain the EMME/2 node number and are related to the FNODE# and TNODE# respectively, the EMME2-ID is computed as follows:
The user must also indicate, in a field called CENTROID, which of these nodes are considered as centroids/centers (with a value of 1) and which as regular nodes (value of 0). The table definition of EMME2.NAT can be found in Appendix A.
The EMME2.MODES table is used as a lookup table for the transportation mode definitions, and is maintained by the user. It may be used for query purposes of mode on arcs (EMME2.AAT) or transit lines (EMME2.RATE2TR). It could be directly obtained from the EMME/2 mode definitions. The table definition of EMME2.MODES can be found in Appendix A.
The EMME2.RATE2TR table stores information about transit line definitions, while the EMME2.SECE2TR table is used to store information about transit line segments. The first field of RAT and the first seven fields of the SEC table are maintained by ArcInfo and are created when a route-system is built. Because we decided to keep a one-to-one relationship between a section and an arc, we have the same relationship between a section (in ArcInfo) and a segment (in EMME/2). The E2TR-ID field of the EMME2.SECE2TR table is used to store a unique section identifier number which assures the correspondence between a section in ArcInfo and a segment in EMME/2. If the EMME/2 coverage is derived from an existing user coverage in the master GIS, then this number is already present, and can be directly exported to an extra attribute in the EMME/2 data bank. However, if the EMME/2 coverage is derived from an EMME/2 network, this identifier must be evaluated in EMME/2. One needs to compute the identifier based on the internal segment index of the EMME/2 data bank and keep the result in an extra attribute (by default @segid). The E2TR-ID is computed as follows: for each transit line, the value of each segment within the line is assigned to the internal segment number plus the value of a variable; this variable contains the maximum segment value of the previous transit line evaluated. We thus obtain a unique value for each segment within all transit lines. This is easily done with an EMME/2 macro.
The ROUTE-ID field (of the EMME2.SECE2TR table) contains an integer value representing the transit line number. It is equivalent to the E2TR-ID field of the EMME2.RATE2TR table. In EMME/2, transit lines are identified by a six character string (LINENAME field of EMME2.RATE2TR table) while in ArcInfo a route is identified by an integer. When exporting to EMME/2, the ROUTE-ID can be directly used as the transit line identifier in EMME/2. When exporting from EMME/2 to ArcInfo, however, a unique numeric line identifier must be computed from the internal line number. The table definitions of EMME2.RATE2TR and EMME2.SECE2TR are in Appendix A.
The EMME2.TRN table stores information related to turns and is created by the TURNTABLE command. The first seven fields of the TRN table contain internal information and are maintained by ArcInfo. The TURN-ID field contains a unique value for each turn, and is evaluated with the expression: ARC1-ID * 100000 + ARC2-ID. It is used to facilitate the joining of attribute tables if specific turn attributes are coming from the EMME/2 data bank. The table definition of EMME2.TRN is in Appendix A.
The EMME2TAZ.PAT feature table stores information related to traffic analysis zones. The first three fields of this table are standard and contain internal information. They are created by ArcInfo when building the polygon topology. The EMME2TAZ-ID field is used to store a unique zone identifier number in order to keep the correspondence between a polygon in ArcInfo and a zone in EMME/2. Since this zone number is also related to the centroid number, you can relate information from the EMME2TAZ.PAT table and the EMME2.NAT table. If the polygon data is coming from an EMME/2 annotation file, the centroid number must be indicated at the beginning of the polygon definition. Appendix A contains the table definition of EMME2TAZ.PAT.
Other attributes (assignment results, extra attributes, ...) can be added as an additional column in the corresponding table. The name of the column should be the same as the name found in EMME/2.
We have chosen to store the road network information in the AAT instead of in a route-system since it is closest to the one-to-one relationship and since many ArcInfo users are probably familiar with the NETWORK data model.
F) Implementation
As a test bench, we have implemented a prototype that extracts, converts and inputs ASCII data from EMME/2 to ArcInfo (E/2->A/I) and vice versa (A/I->E/2). For this implementation, we have considered the first three cases mentioned in the communication process section. The fourth case is more complex, and is not addressed by the prototype. EMARC, the name of the prototype, is composed of:
The prototype is divided in two main parts: the EMME/2 to ArcInfo interface and the ArcInfo to EMME/2 interface.
This option converts a specified EMME/2 scenario into an EMME/2 coverage in ArcInfo. Four different types of information can be converted: the base network and related attributes, the turns and related attributes, the transit lines and related attributes, and the zones and related attributes.
The base network and related attributes
Base network in EMME/2
Figure 3 - Base network in EMME/2
Base network in ArcInfo
Figure 4 - Base network in ArcInfo
The turns and related attributes
Turns in EMME/2
Figure 5 - Turns in EMME/2
The transit network and related attributes
Our experience shows that whenever the NETWORK module is available, the first method should be used, because it is much faster than the iterative method. Again, the user also has the possibility to add other attributes (assignment results, extra attributes or other derived attributes) to the SEC table by specifying the name of the attribute.
Transit network in EMME/2
Figure 6 - Transit network in EMME/2
Transit route-system in ArcInfo
Figure 7 - Transit route-system in ArcInfo
The zones and related attributes
Zones in EMME/2
Figure 8 - Zones in EMME/2
Polygons in ArcInfo
Figure 9 - Polygons in ArcInfo
The whole importing process takes about 120 seconds (on a SPARC 1000E) to transfer a small network of 150 zones, 2975 links, 67 transit lines, and 4205 line segments.
This option converts a specified EMME/2 coverage of the ArcInfo data base into a specified scenario of the EMME/2 data bank. It uses the EXPORT command of the ARC module to export feature tables (AAT, NAT, PAT, TRN) in ASCII format. The UNLOAD command of the TABLES module is also used to create ASCII files for non-feature tables (MODES, etc.). Some AWK scripts are used to convert these ASCII files into EMME/2 data files, which are then read into the EMME/2 data bank using EMME/2 macros.
The whole exporting process takes about 100 seconds (on a SPARC 1000E) to transfer the same small network (150 zones, 1607 arcs, 67 transit lines, and 4205 line segments).
Other option
Another option included in the prototype lets the user plot the base network of the EMME/2 coverage in terms of its directional attributes. A specified attribute is presented in each direction in terms of bar and color depending on the attribute value.
Attribute on base network in EMME/2
Figure 10 - Attribute on base network in EMME/2
Attribute on base network in ArcInfo
Figure 11 - Attribute on base network in ArcInfo
While the prototype described here uses ASCII files for the conversion process, the guidelines and data structures that we have developped can equally be used in the context of binary data exchange.
G) Conclusion
The one-to-one relationship constraint imposed on the EMME/2 coverage eases the process of exchanging data between the EMME/2 data bank and the ArcInfo data base. However, when both the EMME/2 and ArcInfo data bases were designed independently, this constraint implies that the modeling process (see Figure 1) may be very complex, depending on the design of the network coverage in the master GIS. Therefore, there is a need to develop more tools to ease the task of extracting sub-area network from a network contained in an ArcInfo master GIS.
The data exchange process described here is static in nature and does not address the dynamic aspect of the problem: if small modifications are made in one data bank, the complete data set must be exported again. However, we see the current communication process as a necessary starting point toward a dynamic conncection.
H) References
INRO Consultants Inc., EMME/2 User's Manual, Montreal, Quebec, CANADA, 1996.
ESRI Limited, ArcDoc ver. 7.0.4, Redlands, CA, USA, 1995.
Appendix A
This appendix contains the INFO table definitions of the EMME/2 coverage.
Road Network data:
 DATAFILE NAME: EMME2.AAT                                           03/12/1997
   27 ITEMS: STARTING IN POSITION    1
 COL  ITEM NAME         WDTH OPUT TYP N.DEC  Description
    1  FNODE#              4    5  B    -    Internal node number of the
					     from-node of the arc
    5  TNODE#              4    5  B    -    Internal node number of the
					     to-node of the arc
    9  LPOLY#              4    5  B    -
   13  RPOLY#              4    5  B    -
   17  LENGTH              4   12  F    3
   21  EMME2#              4    5  B    -
   25  EMME2-ID            4    5  B    -    A unique arc identifier number which
					     assures the correspondence between an
					     arc in ArcInfo an a link in EMME/2
   29  INODE               8    8  I    -    EMME/2 node number for the from-node
   37  JNODE               8    8  I    -    EMME/2 node number for the to-node
   45  LEN                 4   12  F    3    EMME/2 link length
   49  LENR                4   12  F    3    Same as above for the opposite direction
   53  LANES               4    8  F    1    Number of lanes
   57  LANESR              4    8  F    1    Same as above for the opposite direction
   61  TYPE                6    6  I    -    EMME/2 link type
   67  TYPER               6    6  I    -    Same as above for the opposite direction
   73  VDF                 6    6  I    -    EMME/2 volume delay function number
   79  VDFR                6    6  I    -    Same as above for the opposite direction
   85  UL1                 4    8  F    2    EMME/2 user defined link data
   89  UL1R                4    8  F    2    Same as above for the opposite direction
   93  UL2                 4    8  F    2    See UL1
   97  UL2R                4    8  F    2    See UL1R
  101  UL3                 4    8  F    2    See UL1
  105  UL3R                4    8  F    2    See UL1R
  109  MODE                6    6  C    -    List of modes allowed on the link
  115  MODER               6    6  C    -    Same as above for the opposite direction
  121  SYMBOLS             4    8  F    2    Information used by the plotting routine of the prototype
  125  SYMBOLSR            4    8  F    2    Same as above for the opposite direction
 DATAFILE NAME: EMME2.NAT                                           03/12/1997
    9 ITEMS: STARTING IN POSITION    1
    1  ARC#                4    5  B    -
    5  EMME2#              4    5  B    -
    9  EMME2-ID            4    5  B    -    EMME/2 node number
   13  CENTROID            4    5  B    -    Centroid indicator
   17  UI1                 4    8  F    2    EMME/2 user defined node data
   21  UI2                 4    8  F    2    See UI1
   25  UI3                 4    8  F    2    See UI1
   29  LABEL               6    6  C    -    Optional node label
 DATAFILE NAME: EMME2.MODES                                         03/24/1997
    1  MODE                1    1  C    -    EMME/2 mode identifier
    2  DESCRIPTION        10   10  C    -    Mode description
   12  TYPE                4    4  I    -    Number which identifies the type
					     (auto (1), transit (2), auxiliary
					     transit (3) or auxiliary auto (4))
   16  PLOT                4    4  I    -    EMME/2 plot code
   20  CTC                 4    8  F    2    Operating cost/hour factor
   24  CDC                 4    8  F    2    Operating cost/length unit factor
   28  ETC                 4    8  F    2    Energy consumption/hour factor
   32  EDC                 4    8  F    2    Energy consumption/length unit factor
   36  SPEED               4    8  F    2
Transit network data:
 DATAFILE NAME: EMME2.RATE2TR                                       03/12/1997
   11 ITEMS: STARTING IN POSITION    1
    1  E2TR#               4    5  B    -
    5  E2TR-ID             4    5  B    -    Line identifier
    9  LINENAME            6    6  C    -    EMME/2 line name
   15  MODE                2    2  C    -    Mode of the line
   17  VEH                 6    6  I    -    Vehicle type for this line
   23  HEADWAY             4    8  F    2    Vehicle headway in minutes
   27  SPEED               4    8  F    2    Vehicle default speed in length
					     units per hour
   31  DESCRIPTION        20   20  C    -
   51  UT1                 4    8  F    2    EMME/2 user defined line data
   55  UT2                 4    8  F    2    See UT1
   59  UT3                 4    8  F    2    See UT1
 DATAFILE NAME: EMME2.SECE2TR                                       03/12/1997
   19 ITEMS: STARTING IN POSITION    1
    1  ROUTELINK#          4    5  B    -
    5  ARCLINK#            4    5  B    -
    9  F-MEAS              4   12  F    3
   13  T-MEAS              4   12  F    3
   17  F-POS               4   12  F    3
   21  T-POS               4   12  F    3
   25  E2TR#               4    5  B    -
   29  E2TR-ID             4    5  B    -    A  unique section identifier
					     a segment in EMME/2
   33  ROUTE_ID            4    5  B    -    Line identifier
   37  DWT                 4    8  F    2    EMME/2 dwell time per line segment
					     in minutes
   41  DWTF                4    8  F    2    EMME/2 dwell time factor in minutes
                                             per length unit
   45  NOALI               4    4  I    -    EMME/2 indicator for no-alighting
   49  NOBOA               4    4  I    -    EMME/2 indicator for no-boarding
   53  TTF                 4    4  I    -    EMME/2 transit time function on
					     number on links and turns
   57  TTFT                4    4  I    -    EMME/2 transit time function
					     number on turns
   61  US1                 4    8  F    2    EMME/2 user defined segment data
   65  US2                 4    8  F    2    See US1
   69  US3                 4    8  F    2    See US1
   73  LAY                 4    8  F    2    Layover time in minutes
Turn data:
 DATAFILE NAME: EMME2.TRN                                           03/12/1997
   14 ITEMS: STARTING IN POSITION    1
    1  NODE#               4    5  B    -
    5  ARC1#               4    5  B    -
    9  ARC2#               4    5  B    -
   13  AZIMUTH             4   12  F    3
   17  ANGLE               4   12  F    3
   21  ARC1-ID             4    5  B    -
   25  ARC2-ID             4    5  B    -
   29  TURN-ID            10   10  I    -    A unique indentifier for each turn
   39  ARCID1              5    5  I    -    Identifier of the from-arc (see
					     EMME2-ID in EMME2.AAT)
   44  ARCID2              5    5  I    -    Identifier of the to-arc (see
   49  TPF                 8    8  F    2    EMME/2 turn penalty function number
   57  Up1                 8    8  F    2    EMME/2 user defined turn data
   65  Up2                 8    8  F    2    See Up1
   73  Up3                 8    8  F    2    See Up1
Zone data:
 DATAFILE NAME: EMME2TAZ.PAT                                        03/24/1997
    6 ITEMS: STARTING IN POSITION    1
    1  AREA                4   12  F    3
    5  PERIMETER           4   12  F    3
    9  EMME2TAZ#           4    5  B    -
   13  EMME2TAZ-ID         4    5  B    -    A unique zone identifier number
					     a zone in EMME/2
   17  COLOR               4    4  I    -    EMME/2 color code
   21  PATTERN             4    4  I    -    EMME/2 line pattern code
Robert Lussier, M.Sc.
Information Systems Analyst
INRO Consultants, Inc.
5160, Decarie Boulevard, suite 610
Montreal, Quebec H3X 2H9
Telephone: (514) 369-2023
Fax: (514) 369-2026
Email: robert@inro.ca
Jia Hao Wu, Ph.D.
Senior Analyst
Fax: (514) 369-2026
Email: wujiahao@inro.ca
