Integrating Sewer Modeling and GIS Technologies
Guann Hwang, City of San Diego Metropolitan Wastewater Department
Andrew Baldwin, Montgomery Watson
600 B St., Suite 500
San Diego, CA 92101
ABSTRACT
Wastewater planning requires the use of GIS technologies to facilitate the management of data and implementation of sewer models. In particular, the City of San Diego Metropolitan Wastewater department is currently using a customized ArcView GIS/data management system to model and analyze its sewer system. An ArcView GIS application (ArcADE - ArcView Asset Data Environment) was developed to convert and validate sewer data, process population, land use, and topographic data and export the data to model format. In addition, the ArcADE application provides add-on utilities including radar rainfall animation, time-series viewing, model simplification and hydraulic analysis. The ArcADE application was developed in the ArcView GIS/Avenue environment using Dialog Designer to customize the interface.
SAN DIEGO’S WASTEWATER SYSTEM
The City of San Diego Metropolitan sewer system serves a population of 1.8 million generating an annual average daily flow of 190 mgd. The service area includes the City of San Diego and 14 other wastewater agencies. A network of trunk sewers and interceptors ranging up to 114 inches in diameter convey the wastewater to 2 major pumping stations and on to the Point Loma Wastewater Treatment Plant (PLWTP) and ocean outfall. Collection system facilities within the City of San Diego (representing about 70 percent of the total Metropolitan sewer system) include over 2800 miles of sewers ranging in size from 8 to 114 inches, and 82 pumping stations.
PROJECT REQUIREMENTS
The City has recognized that the growing size and complexity of its wastewater system call for ongoing sewer system modeling and continuous planning. This recognition has led to the development of a dynamic hydraulic model to analyze the existing and future systems. The construction of the hydraulic model focused attention on the need to assemble large amounts of data ranging from physical sewer data (eg; lengths, inverts etc.) through to demographic data for population analysis. It became clear of the need to develop a comprehensive data management system that organized, stored and processed both the tabular and graphical data acquired to build the hydraulic model.
The following sections of this paper describe the processes undertaken to build, calibrate and analyze the hydraulic model using customized tools developed within the ArcView GIS environment.
HYDRAULIC MODELING AND DATA MANAGEMENT PROCESSES
A sustainable planning process requires more comprehensive tools for managing information about a system, whether that information be observed flows and rainfall, physical characteristics and condition of sewers and facilities, changing population and land use patterns, or the results of hydraulic analyses. The following are brief descriptions of tools that the City’s modeling team has developed or adapted to support its efforts.
GIS Databases and Applications
Since most of the information needed for wastewater planning has a spatial component, it is best managed in a geographical information system (GIS) environment. Fortunately, the agencies in the San Diego region were early leaders in adopting GIS technology and that investment has paid dividends for the City’s modeling team. Several different agencies and City departments are responsible for maintaining GIS maps and databases which the modeling team has been able to use productively. Key databases include:
CUSTOMIZED ARCVIEW TOOLS
The hydraulic modeling and data management tools developed to assist the planning and sewer modeling team were created using ArcView’s Avenue programming language and Dialog Designer. The resulting scripts and dialogs were compiled into an ArcView extension and distributed to all users. The modeling and data management tools can be accessed from customized menus, buttons and tools all within the standard ArcView View document window.
The first stage of the development process involved designing the database and graphic file structure. The attribute data (eg; pipe size, length, inverts etc.) are stored in separate (DBF) tables and joined to corresponding graphic (SHP) files using a key field. This approach maximizes the use of the SHP files by joining different forms of attribute data to the same graphic SHP file, in effect ‘normalizing’ the tabular and graphic data. The following details the main hydraulic modeling process tools used for constructing and calibrating the City’s sewer model.
Data Validation
This routine performs extensive data validation checks based on specified rules such as missing lengths, sizes, reverse slopes, connectivity errors etc. The results are displayed on the plan view and with error descriptions ‘joined’ to the attribute data.
Network Trace Manager
The Network Trace Manager is used to verify connectivity errors, select profile views, define model network and identify sub-area basins.
Profile Viewer
The Profile Viewer creates a theme displaying a profile of a selected pipe section. Node and link data can be accessed from the profile view.
Model Export
This routine extracts a selected portion of the City sewer system for re-formatting and export to the City’s modeling software package (HydroWorksTM). The routine has the capability of exporting to various model formats.
Model Results Import
Import of selected results from the modeling program, for graphical viewing and analysis (e.g., highlighting of problem areas on the sewer map).
Hydrograph Viewer
Import of selected flow monitoring data and linkage of that data to the monitor symbols on the GIS map, for displaying flow and depth graphs along with modeling results graphs during the model calibration process.
CONCLUSIONS
The development of the hydraulic modeling and data management toolkit (ArcADE) enabled the City of San Diego Metropolitan Wastewater Department modeling team to efficiently build and calibrate a dynamic hydraulic model of the entire sewer system. ArcADE provided a modern approach to data processing and modeling activities making full use of the benefits of a GIS. In addition, the GIS provided an excellent means of presenting the data to the management and relevant departments within the City. Finally, processing the sewer, demographic, flows and rainfall data within the GIS environment enabled the modeling team to maximize the use of all available data and build a comprehensive 'data warehouse' used to enhance the City's current GIS data services.
