ABSTRACT
To assist water engineers to utilize an advanced water distribution system optimizer, a user-friendly interface, database support, and mapping utilities have been integrated into ArcView 3.1 GIS using AVENUE and the Dialog Designer extension. This decision support system (DSS) is developed into an ArcView extension called WADSOP - Water Distribution System Optimizer. WADSOP optimizes pipe sizing and layout, as well as pump station sizing and layout, to improve cost-effectiveness and reliability over most existing water distribution models based on less effective pipe simulation algorithms. GIS provides functions for development and preparation of accurate spatial information for input into the network design optimization model, which include network layout, connectivity, pipe characteristics and cost, pressure gradients, demand patterns, cost analysis, network routing and allocation, and effective color graphic display of results.
INTRODUCTION
Municipal water distribution systems represent a major portion of the investment in urban infrastructure and a critical component of public works. The goal is to design water distribution systems to deliver potable water over spatially extensive areas in required quantities and under satisfactory pressures. In addition to these goals, cost-effectiveness and reliability in system design are also important.
Municipal water distribution systems are inherently complex because they are:
The optimal design of municipal water distribution systems is a challenging optimization problem for the following reasons:
STATE-OF-ART IN WDS OPTIMAL DESIGN MODELS
The current focus in optimal design models is on improving the efficiency and realism of the optimization techniques, with little attention given to spatial database requirements and dialog interfaces to enhance practical usage. A wide variety of techniques have been proposed, with one of the most oft studied being the Linear Programming Gradient (LPG) method and its extensions (Alperovits and Shamir, 1977; Eiger, et al., 1994). However, Bhave and Sonak (1992) claim that the LPG method is inefficient compared with other methods.
Some approaches attempt to employ efficient combinatorial methods to the optimal design problem. Gessler (1982) linked a network hydraulic simulation model to a filtering subroutine to efficiently enumerate all feasible solutions in pipe network design. This model selects both the optimal design, as well as several near-optimal solutions for tradeoff analysis, and is perhaps the most widely used optimization model. Other authors have formulated the optimal design problem as a nonlinear programming problem with discrete pipe sizes treated as continuous variables. Chiplunkar, et al. (1986) employed the Davidon-Fletcher-Powell method to design a water distribution under a single demand loading scenario. Lansey and Mays (1989) coupled the generalized reduced gradient (GRG) algorithm with a water distribution simulation model to optimally size pipe network, pump stations, and tanks. The primary disadvantage of these NLP methods is the required rounding off of optimal continuous decision variables to commercially available sizes, which can lead to network infeasibilities as well as raise questions as to optimality of the adjusted solution.
Methods based on the use of linear programming (LP) have been developed which are capable of maintaining the constraint on discrete pipe sizes without the need for rounding off solutions. Morgan and Goulter (1985) modified the procedure of Kally (1972) to link a Hardy-Cross network solver with linear programming model. The model is designed to optimize both the layout and design of new systems and expansion of existing systems. It is a highly efficient method, with the main disadvantage being the generation of split pipe solutions (i.e., with some pipe sections requiring two pipe sizes). The latter indeed reduces system costs, but may not be attractive to design engineers.
More recent literature emphasizes reliability issues in water distribution system design, with consideration of the probabilities of satisfying system flow and pressure requirements. Lansey, et al. (1989) employed a chance constrained model to consider uncertainties in demands, pressure head, and pipe roughness. Bao and Mays (1990) applied Monte Carlo simulation methods to measure system reliability. Although reliability-based water distribution system models are useful for analysis of the problem, they may be impractible for designing large-scale systems. The use of multiple demand loading scenarios may be a means of indirectly including system reliability issues at more practical computational expense.
Recent studies have attempted to apply a variety of heuristic programming methods to the optimal design of water distribution systems. These include the application of genetic algorithms (Savic and Walters, 1997) and simulated annealing (Cunha and Sousa, 1999). The advantages of these methods are that they allow full consideration of system nonlinearity and maintain discrete design variables without requiring split pipe solutions. The disadvantages include:
WADSOP GIS APPLICATION DEVELOPMENT
The WADSOP application was developed exclusively in ArcView GIS (3.1) as an extension using AVENUE programming and ArcView project customization capabilities. All dialogs were developed using the Dialog Designer extension to ensure that the application could be used on any platform. The CAD Reader extension was used to permit CAD drawing input, mapping, and conversion, and the Spatial Analyst extension was used for digital elevation model input and usage. One of the most useful extensions incorporated was the Network Analyst for routing new pipes and rerouting old ones, allocating water supply to demand zones, and for developing pressure zones.
WADSOP Menu System
The figure below depicts the WADSOP menu system which functionality
can also be accessed through a toolbar that can be activated from the WADSOP
button in the button bar or toggle on or off from the menu system.
Modules include data development, optimization, results, route, allocate,
and help. The development of each of these modules will be discussed
in detail in the following sections.
Pipe Edit Dialog
Upon selecting data development from the WADSOP menu or input
from the WADSOP toolbar, the Data Development Switchboard is produced
for developing optimization model input. The first option is to Edit
Pipe Links. If data already exists in the ArcView project for
the pipe network, the Pipe Editor dialog is produced along with
a table of attributes, one record for each pipe. The user can choose
a pipe from the drop down list to begin editing it, or choose it directly
from the table. The Select button permits the user to directly
select a pipe from the map for editing. Attributes include the Hazen-Williams
coefficient, and the diameter and length of the pipe. Note that the
user is permitted to add a second diameter and length if the pipe is to
be split to reduce overall system costs. The optimizer automatically
splits pipes in two to use two different diameters to increase system cost-effectiveness
when possible unless the user chooses to not exercise this option.
From the Pipe Editor menu, the user can also choose the Add Pipe
tool to add new pipes to the system. Nodes are automatically generated
at the ends of each pipe added. If the end of a new pipe is drawn
within a user-defined tolerance of an existing node, the existing node
serves as the end node for that pipe.
Edit Nodes
The next data development option is to add pipe nodes and attributes including elevation and up to four demand scenarios. Using multiple demand scenarios insures that the resulting optimized system is robust. It ensures that a pipe is not eliminated as unnecessary or undersized. As with pipes, nodes can be selected directly from the map for editing as well as added or deleted from the Node Edit dialog. Two different kind of nodes can be added, supply or demand nodes. As opposed to demand nodes, supply nodes are added to represent a water supply tank or a reservoir.
Although not entirely functional yet, a script is being developed to allow all node elevations to be estimated from a map of ground elevation contours or a digital elevation model (DEM) grid minus a constant depth-to-pipe factor. Although this is a rough method, it makes data editing easier if values close to what they should be are already in the elevation field of the table. It also allows a rough optimization run to be executed to determine general areas of concern in pipe network design and expansion.
Edit Pipe Diameters and Costs
The third data development option is to set up a table of commercially
available pipe diameters and costs.
By requiring the optimization model to only choose from available diameters,
the feasibility and optimality of the solution is more certain. Updating
pipe costs to current market prices will ensure that the optimal wds design
results reflect reality. The Edit Pipe Cost Factors option
allows design costs to be further adjusted for soil type, landuse and street
width to improve realism, too.
WADSOP incorporates and effective way to optimize pump design as well
as pipe design requiring minimal input. Only the amount of time each
pump is set to run for each loading scenario and its load efficiency are
required in the Edit Load and Pump Data dialog. Pumping head
is automatically adjusted in the optimization model so that all minimum
pressure requirements are satisfied. The Edit Energy and Cost
Data dialog allows parameters to be set to determine when the cost
of additional pumping is less than the cost of increasing pipe sizes, to
compute an overall least cost solution for the wds.
In addition to the cost of a pipe itself, installation costs can be significantly affected by a number of site conditions, three of which include landuse (developed land being more expensive to excavate), road width (narrow roads causing more disturbance when under construction), and soil type (loose soils requiring shoring and firm soils more time and energy to excavate than typical). The Edit Pipe Cost Factors dialog allows these factors to considered by applying a factor to the cost of pipe based on site conditions. Road buffer, soils and landuse maps are prepared and spatial joins of their linked attributes used to develop an overall factor to apply to each pipe. The user can adjust the cost factors in the dialog and recalculate pipe costs before proceeding to optimization at any time. Adjusting costs and reruning the optimizer is a good way to determine how sensitive results are to changing conditions.
Help
Currently, every dialog includes a help button to obtain text-based information to assist the user in proceeding through the options as well as more general help accessed from the menu-system with details about the WADSOP application. A future goal is to replace this help system with a standard Windows-based one that includes hyperlinks, graphics, and a find function.
Optimization
After completing each dialog in the Data Development module the
user is ready to use the WADSOP optimizer. Currently only the optimizer
is available, but the simulator to analyze existing systems will soon follow.
The Data Verification Check dialog allows the users to review information
about the system and return to the editing mode if necessary before proceeding.
When the user chooses Optimize from this dialog, all the tables
developed during the input phase are converted to comma deliminated text
and sent to the WADSOP executable. Results are written to the pipe
and node tables, and map displayed colored coding changes to the original
network and displaying pipes with a graduated symbol related to pipe diameter.
Split pipes are also noted in the results with text labels.
The Crystal Reports extension can be used to generate typical wds reports
of interest, as well as customized reports if desired.
Network Routing
Although the main purpose of WADSOP is network optimization, ArcView GIS can provide a great deal of additional functionality. Through the use of the Network Analyst extension, the least cost path can be determined for planning a new pipe along an existing road network. The user only has to indicate from where to where they wish to route, and if length or some other impedance factor will determine which way is the "longest".
Allocation
The final WADSOP module being developed to date aids in network allocation. Two common uses are for determining which water supply sources can supply which sectors of a municipality, or for defining pressure zones as the distance out from a pressure supply head (pump) that can be serviced before impedance along pipes causes the minimum pressure to be reached.
CONCLUSIONS
Although significant progress has been made on the WADSOP extension to ArcView GIS to date, it is not ready for commercial distribution at this time. However, the authors would look forward to entities that would like to test the beta and offer recommendations for improvements. Some of the most pressing work includes the following:
Alperovits, E. and U. Shamir, Design of optimal water distribution
systems, Water Resour. Res., 13 (6), 885-900, 1977.
Bao, Y. and L. Mays, Model for water distribution system reliability,
J. Hydraul. Div. Am. Soc. Civ. Eng., 116 ( 9), 1119-1137, 1990.
Bhave, P., and V. Sonak, A critical study of the linear programming
gradient method for optimal design of water supply networks, Water
Resour. Res., 28 (6), 1577-1584, 1992.
Chiplunkar, A., S. Mehndiratta, and P. Khanna, Looped water distribution
system optimization for single loading, J. Env. Eng. Div. Am. Soc.
Civ. Eng., 112 (2), 264-279, 1986.
Cunha, M. and J. Sousa, Water distribution network design optimization:
simulated annealing approach, J. Water Res. Plan. Manage. Div. Soc.
Civ. Eng., 125 (4), 215-221, 1999.
Eiger, G., U. Shamir, and A. Ben-Tal, Optimal design of water distribution
networks, Water Resour. Res., 30 (9), 2637-2646, 1994.
Gessler, J., Optimization of pipe networks, Proc. of the Ninth
International. Symposium on Urban Hydrology, Hydraulics and Sediment Control,
Univ. of Ky., Lexington, July 27-30, 1982.
Goulter, I., Systems analysis in water distribution system design:
from theory to practice, J. Water. Res. Plan. Manage. Div. Am. Soc.
Civ. Eng., 118 (3), 238-248, 1992.
Lansey, K., N. Duan, L. Mays, and Y. Tung, Water distribution system
design under uncertainties, J. Water Res. Plan. Manage. Am. Soc. Civ.
Eng., 115 (5), 630-645, 1989.
Lansey, K. and L. Mays, Optimization model for water distribution
system design, J. Hydraul. Div. Am. Soc. Civ. Eng., 115 (10), 1401-1418,
1989.
Morgan, D., and I. Goulter, Optimal urban water distribution design,
Water Resour. Res., 21 (5), 642-652, 1985.
Savic, D. and G. Walters, Genetic algorithms for least-cost design
of water distribution networks, J. Water Res. Plan. Manage. Div. Soc.
Civ. Eng., 123 (2), 67-77, 1997.
Taher, S. and J. Labadie, Optimal design of water distribution networks
with GIS, J. Water Res. Plan. Manage. Div. Soc. Civ. Eng., 122
(4), 301-311, 1996.
AUTHOR INFORMATION
John W. Labadie, P.E.
Professor, Dept. of Civil Engineering
Colorado State University
Fort Collins, Colorado 80523-1372
Tel: 970-491-6898
Fax: 970-491-7727
email: labadie@engr.colostate.edu
Margaret T. Herzog, P.E.
Civil Engineer / GIS Coordinator
Foothill Engineering Consultants, Inc.
350 Indiana Street, Suite 315
Golden, Colorado 80401
Tel: 303-278-0622
Fax: 303-278-0624
Home: 303-237-4158
email: mherzog@foothilltmc.com
