Brian Murray, Roger Koelpin, Kevin Miller
A Method Using GIS Coverages and GPS Equipment for Determining Well Locations for Regulated Facilities in Northwest Indiana for the Indiana Department of Environmental Management, Hazardous Waste Geology Section
Abstract:
The Indiana Department of Environmental Management (IDEM) received a grant to develop a Geographic Information System(GIS) for the region of Northwest Indiana as part of the U.S. EPA Great Lakes Initiative. Part of this initiative was to develop groundwater quality data for the area. The problem the group faced was how to incorporate 1600 wells at 58 facilities into the database. Each facility that IDEM is working with had been surveyed as part of its involvement with the regulatory process. These maps were accurate within the confines of each facility survey. However, there was no way to relate them spatially, as each individual site-survey had been conducted in a unique coordinate system. A common coordinate system was needed. Traditional survey methods would be too time-consuming and costly for this task. However, GPS equipment and Esri's ArcInfo software could be used to accomplish this task more efficiently and economically.
Each facility submitted either a paper or digital facility map with well locations. The maps were field-checked to determine suitable locations for GPS control points. They were then rectified using the surveyed control points and Esri's ArcInfo software by transforming them into UTM coordinates. This project took three years to complete and included 58 regulated facilities, 1600 wells, and 162,000 water quality records. Transforming the facility maps into a real world coordinate system allowed staff to integrate these coverages with those developed from other state and federal agencies in assessing the impact of these facilities on the environment of Northwest Indiana.
Introduction:
In 1991, the Indiana Department of Environmental Management established funding to develop a Geographic Information System. This funding is provided through EPA grant funding of the Great Lakes Initiative; a project designed to facilitate environmental cleanup of Northwest Indiana, including Lake, Porter, and LaPorte counties, which lie on the southern boundary of Lake Michigan. It is but one of 43 Areas of Concern around the Great Lakes, established by the International Joint Commission in conjunction with the Great Lakes Water Quality Agreement between Canada and the United States. An Area of Concern is designated as an area where all entities involved, including private groups, industry, and governmental bodies, work to minimize the environmental impact of that area on the Great Lakes. Funding for this project is provided by the Great Lakes Initiative Program Element of EPA's annual Resource Conservation and Recovery Act 3011 grant to the Indiana Department of Environmental Management (Koelpin & Goldblatt, 1996).
After receiving funding for this project, work began in earnest in 1993 to develop the GIS. A major effort began in the Hazardous Waste Geology Section of the Office of Solid and Hazardous Waste Management (OSHWM). Staff began creating a series of base map coverages for regional groundwater analysis in Northwest Indiana. These base maps included data for both possible contaminant sources and receptors. A large amount of groundwater data existed for this region in the EPA Region V groundwater monitoring data set, known as GRITS (Groundwater Information Tracking System). This data represented monitoring over a two year period for 1500 wells located on 58 facility sites, and represented a 162,000 record table. However, the monitoring wells did not have any locational attributes assigned to them. Secondly, the facility maps from which the digitized locational data could be obtained were all in unique coordinate systems (plane coordinates), created by the staff that surveyed the facility. Therefore, the top priority for staff in the Geology Section was to define accurate locations for all of the monitoring wells in the GRITS data set within a common coordinate system.
GPS Applications:
The question that faced the staff was "How to collect this locational data?" With over 1500 wells needing to be surveyed, the most cost-effective and timely method would need to be utilized. Classical survey methods were deemed excessive. First and foremost was the consideration of time. Classical survey methods employ "line-of-sight" surveying techniques. Bringing survey control in from off-site locations would be too time-consuming. Secondly, it was unknown if the survey control existed for such a large task. Another method considered was Global Positioning System technology (GPS). GPS technology could provide the means to determine real-world locations without surveying line-of-sight. However, this was still an overwhelming task. Over 1500 well locations would need to be surveyed by a crew based out of Indianapolis. There was neither the funding, nor the time to supply personnel to accomplish this. A third method could be employed involving both methods. Most of the 58 facilities had been surveyed with traditional survey methods to provide facility management information. Rectifying these surveys with a real-world coordinate system through GPS techniques would take advantage of existing survey data and minimize the field time necessary to complete the project.
Although the well coordinates would be derived from pre-existing information, if this could be accomplished with a permissible level of error, then this would be acceptable. It was decided to use this method and define at least two control points at each facility with GPS techniques. Usually, at least three sets of coordinates are used as control to transform from one coordinate system to another. Two sets of coordinates will define the plane, but a third set of coordinates statistically defines the distortion and displacement, known as the Root Mean Square error (RMS error), created by the process of transformation. This defines the accuracy of the control coordinates in relation to the source map.
Unfortunately, in this project, a number of the facility maps to be used were of poor quality and impeded the use of RMS error. Two of the largest facilities' drawings, submitted digitally, were too large and detailed to create as one file. Therefore these facilities digitized and created at least two drawing files per facility map. When these files were appended, significant distortion and displacement occurred. Many facilities submitted photocopies of the original hardcopy maps, which distorted scale and dimension. A few of the facility maps submitted were not maps but drawings, with no scale or spatial relevance. And a final set were outdated maps, having been created by the last facility to own the property, since abandoned and under the jurisdiction of the U.S. EPA as a Superfund Site, and managed by IDEM. With these considerable source errors inherent in the facility maps, RMS error proved meaningless in many instances. Therefore, it was decided to only collect two points per facility. In instances where facilities were large and digital data was available, at least three control points were used.
Considering the error already inherent in the transformation process through digitization, scale, and possible source map error, it was decided to purchase survey-grade GPS equipment to minimize the amount of error introduced through data collection. Requisitions for GPS equipment were initiated in 1993. Requests were made for 3 Trimble 4000SE Land Surveyors and peripherals. The 4000SE is single-frequency survey-grade receiver with technical specifications of (1cm + 2ppm x baseline length) horizontal accuracies and (2cm + 2ppm x baseline length) vertical accuracies. Equipment was purchased in 1994. From April of 1994 through August of 1996, eight surveys were conducted at 58 facilities in the region of Lake, Porter, and LaPorte counties.
GPS is a relatively new technology, having been developed by the Department of Defense in the early 1970's. In the early 1980's, it began to have practical civilian applications and equipment was developed and sold commercially for civilian use. However, it is not a failsafe technology. It does have its limitations and drawbacks. First and foremost is where you can use GPS. A GPS receiver acquires radio signals transmitted from satellites, which it uses to determine distances to those satellites, and from that information its location. However, these signals can be blocked by obstructions such as buildings or trees, and they can be corrupted by reflective objects located near the GPS units. Secondly, it is only as accurate as the control you are utilizing. One may be able to conduct an inherently precise survey. If this survey is adjusted to poor control, however, the precision is meaningless. Therefore, the most important aspect of GPS surveying is the initial pre-planning. Staff would visit the area approximately one week prior to an event to verify existing control and to visit the facilities to be surveyed to ground truth the facility map and establish survey locations. All control points used in this project were National Geodetic Survey monuments, 1st and 2nd order, constrained to the NAD83 datum. Facility survey locations were generally established at monitoring wells located on site. However, if this was not possible due to possible satellite signal interference, a property corner or other easily rectifiable feature was used for the survey location.
The surveys were usually 2 to 3 day events involving approximately 10 to 12 people. The project coordinators were able to utilize six receivers in the field by borrowing 3 Trimble 4000SE Land Surveyors from the Office of Environmental Response. Once the survey was completed the data was processed back in Indianapolis, along with running it through a least squares adjustment. However, due to the fact that the three counties surveyed are approximately 160 miles from Indianapolis, a laptop computer was eventually taken into the field to process the data after each field day to determine if any points needed to be reoccupied.
Digitization/Rectification:
Once the GPS data had been processed, Universal Transverse Mercator (UTM) coordinates were established for the facility control points. The facility maps were then rectified with the UTM coordinates. The facilities had either submitted a hard copy or digital map of the facility. If a hard copy had been submitted, the paper map was digitized. This was usually accomplished in AUTOCAD. This process was rather straightforward. By calibrating the digitizer with the UTM facility control points, all digitizing was then performed within the UTM coordinate framework. After digitization was complete, the drawing was then exported into an ArcInfo workspace as a DXFfile (drawing interchange file). Within ArcInfo, the file was then converted to an ArcInfo coverage with the DXFARC command. This command allows the user to combine specific layers and features from the AUTOCAD drawing into specific coverages. Within the framework of this project, five specific coverage types were created for each facility; an annotation coverage for labels of all features, a boundary coverage of the facility property boundary, a facility coverage, including roads, buildings, tanks, pipelines, lagoons, etc., a units coverage for solid and hazardous waste units located on site, and a wells coverage including the monitoring wells of the GRITS data set.
Digital map data, usually submitted as either an AUTOCAD .DWG file or a DXF file, was converted into coverages using the same process described previously. The coverages created were rectified to the UTM coordinate system by a transformation. This is performed by using the TRANSFORM command in ArcInfo. A transformation rotates, scales and translates each feature from one coordinate system into another. The original coverage coordinates are moved by using a second coverage, created with a set of control points, as a template. When staff first began conversion of digital data into UTM coordinates, they were using CAD software to scale, move, and rotate each drawing. This was time-consuming and inefficient. Scaling calculations had to be performed by hand, and each command had to be invoked separately. Additionally, a compounded amount of displacement error was created each time one of these commands was used. The TRANSFORM command in ArcInfo invoked these processes intrinsically, and if three or more control points were used, an RMS error was generated to alert staff to the amount of distortion which occurred during this process (Esri, 1992).
The final procedure in this process was to define the projection of the coverages. All coverages were rectified to the Universal Transverse Mercator coordinate system, zone 16. The datum used was NAD83. The data was then linked to the GRITS data set by creating key fields in the point-attribute-tables of the well coverages. These key fields included a facility ID number, and the monitoring well ID.
Analysis:
After the coverages were created, they were brought in and analyzed in either ArcInfo or ArcView against other facility coverages and/or other basemap coverages, such as Tiger data, for any visible anomalies. Most facility coverages fit well relative to other base maps. The few coverages that did not fit could be traced to source map error.
A baseline confirmation survey was conducted with survey-grade GPS receivers in the spring of 1997 to determine the accuracy of the derived locational data method used by IDEM (Koelpin & Others, 1997). Part of this study was to compare the derived locational data method used by IDEM to direct GPS mapping-grade methods used by the EPA. A number of the monitoring wells with derived locations in the IDEM data set had been surveyed with mapping-grade GPS units by the U.S. EPA in another project in the area. Due to time and budget constraints, a subset of 10% of these were selected for the baseline survey. IDEM averaged a difference of 17.8 meters from the confirmed locations. EPA averaged a difference of 9.17 meters from the confirmed locations.
While IDEM's derived locational method was not as accurate as EPA's direct mapping, the number of wells assigned locations was almost five-fold. IDEM took approximately three years to complete their project. EPA conducted their survey over a two year period. Secondly, the 17.80 meters of difference in the IDEM project was well within EPA's stated goal of 25 meters or less for locational data accuracy standards, which was the benchmark used in this project (US EPA, 1992).
Conclusions:
Source map error was the most difficult problem to resolve in this project. However, there is currently no legislation or policy in place to mandate the accuracy or coordinate system of the locational data that a facility submits as part of the reporting process. Despite this obstacle, the methods used to derive coordinate locations for monitoring wells met the requirements of this project, which is the EPA accuracy goal of 25 meters or less.
Survey-grade GPS equipment may be unnecessary for locational data control in this type of project. Sub-meter mapping grade GPS equipment would have met the needs of the staff and would have provided acceptable data cheaper and in a shorter amount of time. Hazardous Waste Geology is presently purchasing new sub-meter mapping-grade equipment. The survey-grade GPS equipment is now being utilized for engineering and compliance efforts in topographic surveying. So, it is now serving a multi-purpose role.
Even with the cost of survey-grade equipment, the cost of completing this project was one-quarter to three-fourths that of similar work being contracted in another region of the state, depending upon how staff time and equipment costs are handled.
The Future:
IDEM is moving forward in its use of GPS and GIS to develop locational data. We are in the process of moving to a cross-media philosophy in our regulation and assessment of the environment. We realize that in looking at the environmental impact of the regulated community, the corporate nature of the processes which drive the environment must be considereded as a whole. To do this the specific program areas in IDEM are beginning to integrate their data for this purpose. GIS will be the catalyst to drive this process. And within GIS, Global Positioning System technology will be the future of locational data capture. The accuracies and precisions of the equipment, the ease of use, and the ability to acquire data in real time will make GPS both cost and labor effective. A number of different programs within IDEM are realizing the power of both GPS and GIS and are now in the process of purchasing GPS equipment for data capture to develop their own GIS databases.
A second step IDEM is taking to improve locational data development is in the creation of agency-wide GIS and GPS data standards. As data development continues in the agency and more areas become involved in data-sharing, it is imperative that there is consistency in the work conducted within the agency. Therefore, a committee has been created to develop a set of standards for documentation purposes that will be included with every source GIS coverage created. These will then be archived as source data in a central repository so that as personnel pull this information into their various projects, there will be reliable information on source and scale of this data.
A third step IDEM is taking to improve locational data development is in the standardization requirements for data submitted by the regulated community. Although not mandated by regulation, it is hoped that these standards will be received in the spirit with which they were created. As GIS development moves across the state for IDEM, the agency will need to rely on data submitted by our customers, as the agency does not have the resources to capture all necessary data . With a consistency in locational data submitted to our agency, there will be an improvement in the efficiency of our analyses and reviews. These standards will include all data submitted in a digital format, consistency in scale of facility maps, and standards and specifications for all locational data collected by outside contractors.
A final step which will improve locational data is the development of a HARN (High Accuracy Reference Network) in Indiana. As of now, the best control being used for most GPS work is at a precision of 1:100000, whereas the HARN points will have a precision of approximately 1:1000000. By creating a network of high precision control points, and adjusting the existing NAD83 datum to this network, both precision GPS work and traditional survey methods will be improved across the state. This survey is scheduled for the summer of 1997.
References:
Environmental Systems Research Institute, 1992, ARC Command References, Version 6.0, April 1992, Environmental Systems Research Institute, Redlands, California
Koelpin, R.U., Goldblatt, I.A., 1996, GIS Development in the Hazardous Waste Geology Section, Office of Solid and Hazardous Waste, Indiana Department of Environmental Management, in Proceedings 1996 Annual Users Conference, May 1996, Environmental Systems Research Institute, Redlands, California
Koelpin, R.U., Murray, B.R., Miller, K.H., 1997, A comparison of Three Vintages of Groundwater Monitoring Well Locations in the Indiana Department of Environmental Management, Hazardous Waste Geology Section's GIS, in Press, 1997 Annual Users Conference, July 1997, Environmental Systems Research Institute, Redlands, California
United States Environmental Protection Agency , Administration and Resources Management, 1992, Locational Data Policy Implementation Guidance, Guide to the Policy, March 1992, 220 B-92-008, Washington, D.C., United States Environmental Protection Agency, Administration and Resources Management
Brian Murray, Geologist
100 North Senate Avenue, P.O. Box 6015
Indianapolis, Indiana 46206-6015
Telephone:(317)-233-1509
Fax: (317)-232-3403
Roger Koelpin, Geologist
Telephone:(317)-232-8726
Fax: (317)-232-3403
Kevin Miller, Geologist
Telephone:(317)-233-5298
Fax: (317)-232-3403
