Zeyuan Qiu, Tony Prato and Chris Fulcher
The Center for Agricultural, Resource and Environmental Systems (CARES) at University of Missouri-Columbia developed a watershed management decision support system (WAMADSS) by integrating ArcInfo GIS with AGNPS, the Soil and Water Assessment Tool (SWAT) and the Cost and Return Estimator (CARE) model to aid in development of water quality management plans. WAMADSS offers the capability to determine the appropriate resolution in a timely fashion because a graphic user interface streamlines the process of generating input parameters, executing the models and viewing results.
This application is conducted in Goodwater Creek watershed, Missouri. WAMADSS is used to automatically generate a number of input parameters from land use, soil, hydrology and hypsography layers, run the AGNPS model, and present water quality simulation results. Two data resolutions are used: 200 by 200, 100 by 100 square meters grid cells. The simulated water quality results with the different data resolutions are compared within the watershed and at the watershed outlet. The purpose of this paper is to show the differences in water quality simulation caused by data resolution and their implications for AGNPS users.
The Agricultural nonpoint source pollution model (AGNPS) (Young et al., 1987) is a widely-used biophysical simulation model used to estimate water quality impacts of agricultural practices in a watershed. AGNPS is a spatially distributed, single-event watershed simulation model that uses landuse, soil, hydrology and hypsography data and subdivides complex watersheds into grid cells. It is intended to provide basic information on water quality to be used to classify nonpoint source pollution problems in agricultural watersheds. The model provides outputs on runoff, upland erosion, channel erosion, and sediment yield, and nitrogen, phosphorus, chemical oxygen demand (COD) in runoff and sediment (Young et al., 1987). The new version of AGNPS estimates pesticide movement in soil and runoff. Development of an annualized version of AGNPS is in progress.
A geographical information system (GIS) is a system of hardware, software and procedures designed to support the capture, management, manipulation, analysis, modeling and display of spatially-referenced data for solving complex planning and management problems (Burrough, 1986). Since AGNPS uses a distributed parameter approach to quantify a watershed by dividing the area into small grid units within the watershed, it is appropriate to use a GIS to storage and process those spatial characteristics (Mitchell et al., 1993). Several efforts have been made to integrate GIS with AGNPS to evaluate agricultural nonpoint source pollution. Tim and Jolly (1994) developed an integrated GIS and hydrologic/water quality model using ArcInfo GIS and AGNPS to evaluate agricultural nonpoint source pollution. He et al. (1993) used an integrated AGNPS and GRASS GIS package, GRASS WATERWORKS, to evaluate the impact of agricultural runoff on water quality in the Case River, a subwatershed of Saginaw Bay. Mitchell et al. (1993) developed an integrated AGNPS/GIS (GRASS) system to validate the AGNPS for predicting runoff and sediment delivery from small watersheds of mild topography. Srinivasan et al. (1995) developed a spatial decision support system using AGNPS and GRASS GIS to assess agricultural nonpoint source pollution.
In this paper, data resolution refers the size of grid cell used to delineate a watershed. Data resolution is a key factor in the AGNPS modeling process since the grid cells serve as a "cookie-cutter" for other spatial input data including soil, landuse, hydrology and hypsography. The smaller the grid cell, the more number of grid cells for a given watershed. AGNPS only permitted a watershed to be divided up to 1,900 cells in version 3.65 (2,800 cells in version 5.0) due to the memory constraints on the personal computer. The cell size limitation is overcome by compiling AGNPS on a UNIX workstation where the GIS resides (Fulcher, 1996). Using digital input data and integrating AGNPS with GIS makes it possible to readily delineate a watershed into a grid cells size dictated by the user. The smaller the grid cells, the higher the data resolution and accuracy. However, there is a higher cost in term of processing speed and storage requirements. As the application objectives change, the data resolution for generating AGNPS input parameters may change as well. Selection of data resolution can be an important issue for AGNPS model users in light of objectives. The purpose of this paper is to show the differences in water quality simulation caused by data resolution and their implications for AGNPS users.
AGNPS was used to estimate the water quality impacts in Goodwater Creek watershed during the corn season of farming system 1 defined in MMSEA project. Farming system 1 represented the prevailing farming system in the study area, and was a corn-soybean rotation with conventional tillage and high pesticide and fertilizer applications. The storm event used for running AGNPS was 2.4 inch rainfall in 24 hours. This application also assumed there were no point pollution sources (feedlot and non-feedlot), no gully erosion and no impoundments in the watershed. WAMADSS was used to automatically generate a number of input parameters from land use, soil, hydrology and hypsography layers, run the AGNPS model, and present water quality simulation results. Two data resolutions were used: 200 by 200 and 100 by 100 square meter grid cells. The simulated water quality results with the different data resolutions were compared within the watershed and at the watershed outlet.
Table 1 compared the water quality impacts at the watershed outlet simulated by AGNPS with different data resolutions. It seemed that data resolution did not cause significant differences in runoff, soil loss and pesticide pollution. As shown in Table 1, runoff with 200 meter resolution is 1.16 inches, which is slightly higher than 1.15 inches with 100 meter resolution, while total sediment yield with 200 meter resolution is 2,951 tons which is slightly lower than 2,982 tons with 100 meter resolution. However, there are significant differences in the estimation of nutrient pollution. The nutrient pollution indicators refer to total soluble nitrogen, phosphorus, and chemical oxygen demand (COD), and their concentration levels in runoff. The nutrient pollution estimated with 200 meter resolution data is generally 20 percent higher than with 100 meter resolution.
Also, the sediment movement is more clearly identified with more accurate input data. As shown in Table 1, with the two different resolution input data, even though the sediment yields at the watershed outlet are almost same, the sediment generated within cell and the sediment deposition rate within the cell are different. The sediment generated within cell and the sediment deposition rate within the cell are 2.35 tons per acre and 71.01 percent with 100 meter resolution, which are higher than 1.60 tons per acre and 62.63 percent with 200 meter resolution, respectively. With high resolution input data, AGNPS identified more sediment generation and deposition activities in the watershed.
Table 1. Comparison of AGNPS Outputs between the Two Data Resolution
Water Quality Indicators Units 100 Meter 200 Meter Percent at Watershed Outlet Resolution Resolution Change Runoff inches 1.15 1.16 +0.87 Total Sediment Yield tons 2981.97 2951.13 -1.03 Average Sediment Yield tons/acre 0.16 0.15 -6.25 Sediment within Cell tons/acre 2.35 1.60 -31.91 Sediment Deposition in Cell percent 71.01 62.63 -11.80 Sediment Attached Nitrogen lbs/acre 0.58 0.54 -6.90 Sediment attached Phosphorus lbs/acre 0.29 0.27 -6.90 Total Soluble Nitrogen lbs/acre 1.27 1.51 +18.90 Soluble N. Concentration ppm 4.60 5.48 +19.13 Total Soluble Phosphorus lbs/acre 0.54 0.66 +22.22 Soluble P. Concentration ppm 1.98 2.41 +21.72 Total Soluble COD lbs/acre 7.18 8.70 +21.17 Soluble COD Concentration ppm 26.56 31.97 +20.37 Average Soluble Atrazine lbs/acre 0.05 0.05 0.00 Soluble Atrazine Concentration ppm 0.18 0.19 +5.56 Average Atrazine Leached lbs/acre 0.08 0.08 0.00
WAMADSS was used to simulate the water quality impacts of agriculture in Goodwater Creek watershed, Missouri. The AGNPS outputs with two different data resolution (100 by 100 meter and 200 by 200 meter) were reported. The results show that data resolution did not cause significant difference in estimating the soil loss and pesticide pollution. However, The nutrient pollution estimated with 200 meter resolution data is generally 20 percent higher than with 100 meter resolution. Also, the sediment movement is more clearly identified with more accurate input data. These results are important for AGNPS users to select appropriate data resolution in light of their objectives.
Burrough, P.A. 1986. Principles of Geographical Information Systems for Land Resources Assessment. Oxford University Press Inc., New York. Fulcher, C.L. 1996. A Watershed Management Decision Support System (WAMADSS) - Economic and Environmental Impacts of Land Use Activities for Reducing Nonpoint Source Pollution. Unpublished Ph.D. Dissertation. University of Missouri, Columbia, Missouri.
He, C., J.E. Riggs and Y.T. Kang. 1993. Integration of Geographic Information Systems and A Computer Model to Evaluate Impacts of Agricultural Runoff on Water Quality. Water Resources Bulletin 29(6): 891-900.
Missouri MSEA Team. 1995. The Missouri Management Systems Evaluation Area Research and Education Report: 1990-1995.
Mitchell, J.K., B.A. Engel, R. Srinvasan and S.S.Y. Wang. 1993. Validation of AGNPS for Small Watersheds Using an Integrated AGNPS/GIS Systems. Water Resources Bulletin 29(5): 833-842.
Srinivasan, R., B.A. Engel. 1995. A Spatial Decision Support System for Assessing Agricultural Nonpoint Source pollution. Water Resources Bulletin 30 (3): 441-452.
Tim, U.S. and R. Jolly. 1994. Evaluating Agricultural Nonpoint Source Pollution Using Integrated Geographic Information Systems and Hydrologic/Water Quality Model. Journal of Environmental Quality 23: 25-35.
U.S. Department of Agriculture, Soil Conservation Service. 1994. Cost and Returns Estimator: Users Guide.
U.S. Environmental Protection Agency, Office of Water. 1994. National Water Quality Inventory: 1992 Report to Congress, Washington DC, EPA 841-R-94-001.
Young, R.A., C.A. Onstad, D.D. Bosch, and W.P. Anderson. 1987. AGNPS (Agricultural Non-point source Pollution Model): A Watershed Analysis Tool, Conservation Research Report, USDA ARS, Washington, DC.
Tony Prato
Professor of Resource Economics and Management, and Director, CARES
200 Mumford Hall
Columbia, MO 65211
Telephone: (573)882-0147
Fax: (573)882-3958
Chris Fulcher
Research Associate and Associate Director, CARES
200 Mumford Hall
Columbia, MO 65211
Telephone: (573)882-6534
Fax: (573)882-3958
