Kelly L. Wetteroff, Dr. Ronald D. Drobney, Timothy L.
Haithcoat
EVALUATING VERTEBRATE DISTRIBUTION MODELING
WITHIN A GIS FRAMEWORK
Abstract
We will present a methodology for creating predicted
vertebrate ranges for Gap Analysis utilizing species specific
perceptions and spatial constraints based on measures of the
environment and landscape within which they live. This methodology
utilizes many more capabilities of GIS as well as incorporating
statistical measures of landscape to refine the spatial extent of a
species range. We will include discussions of scale, patch, matrix
measures, and landscape context and structure, as they relate to the
selection and modeling of vertebrates. Our pilot study covers 4
counties in mid-Missouri. We have collected statewide information on
distributions and habitat preferences for many species within each
terrestrial taxon for the development of a comprehensive statewide
digital database. This database will be used in association with the
Missouri land cover map to determine areas of suitable habitat within
the known geographical range of each species modeled.
Introduction
We have been developing and evaluating new methodologies for
modeling vertebrate distribution as part of the Missouri Gap Analysis
Program. By way of a brief introduction, Gap Analysis is a federal
program, implemented at the state level, and intended to be a rapid
and coarse overview of current biodiversity protection status (Scott
et al. 1993). Gap Analysis assesses the distribution of wildlife
species by analyzing existing species distributions and the
protection status afforded to them from the land ownership or
management practices on associated lands. Gap Analysis originated
from a lack of success with the species-by-species approach to
conservation, which ignores the primary reason for the loss of
biodiversity, the continual loss of habitat and the fragmentation of
natural landscapes (McNeely et al. 1990, Bridgewater 1993).
The Gap Analysis Program incorporates three data layers to reach an
assessment of protected and unprotected areas. These layers are a)
actual vegetation - derived from satellite imagery and ancillary
data,
b) wildlife species habitat and range information, and c) land
ownership/management status. The GAP theory in combining these layers
is that a species has a high probability of being present in areas of
suitable habitat within the known distributional limits of the
species (Csuti 1993).
Several specific pieces of information are involved in creating
vertebrate distribution models. These are:
1. Habitat association data; correlating habitat types identified
within the literature with the vegetation types discriminated on the
vegetation image map.
2. Wildlife - habitat matrix; recording and modeling which components
of the habitats mapped are associated with which vertebrate
species.
3. Known range information; maps of the known distributional limits
of the vertebrate species and any associated locational or breeding
information.
The development of vertebrate models requires the compilation of a
database of wildlife species and their preferred habitats. Typical
sources for this information include local expert information and
records published in the literature. We were fortunate to have access
to the Missouri Fish and Wildlife Information System (MoFWIS), a
wildlife database managed and maintained by the Missouri Department
of Conservation (MDC). We have relied on this database for
information such as species-habitat associations and average home
range size. When this information was modeled against the map of
habitat types, we were able to designate areas of potentially
suitable habitat for each species under consideration.
Producing maps of predicted vertebrate distributions also requires a
comprehensive database of known vertebrate ranges. Vertebrate ranges
are usually generalized from records initially recorded as point
locations. Typical sources of point location data are: museum
records, published research and other field observations, Natural
Heritage Program databases, and Breeding Bird Atlas databases. These
point sources must be generalized into a polygon (or polygons)
representing the range of the species. In Missouri, for both herptile
and mammalian distributions, we relied on published generalized range
maps from regional experts. We digitized these maps into our
database. Avian range information was obtained through a cooperative
effort with MDC. These records were already generalized into
distribution by USGS quadrangle.
Methodology
The basic Gap Analysis vertebrate model is quite simple: if a
species uses a particular habitat type, all polygons of that type are
included in a map of suitable habitat. Other digital layers may be
used where available and appropriate, such as elevation, climate, and
soil, to more realistically represent areas of suitable habitat. The
second step in Gap Analysis vertebrate modeling is a simple overlay
of the habitat map (the vegetation map) with a map of each species'
distributional limits to result in the elimination of habitat
polygons outside the known range of the species. A final species map
is an illustration of all suitable habitat areas within the known
geographic range of the species. However, we feel that there are many
additional measurable habitat components which can be included to
provide a more accurate species map.
In the currently developing field of landscape ecology, attempts are
being made to identify important landscape components affecting
wildlife habitat and to quantify their structure. Many of these
habitat elements and measures may be easily included in the models
through the use of GIS. Some of these significant habitat variables
are: juxtaposition and interspersion of habitat types, identification
of core areas, contrast between edge and adjacent area, the
proportion of different habitat classes within a specified area,
distance measures (i.e., from roads/human habitation or from water),
and area measures.
In order to perform this species modeling, we first needed a base
habitat map. This was developed from a vegetation map derived from
classified Landsat TM imagery. Within ArcInfo, we decided to use the
GRID module for our vertebrate modeling. We chose to use the grid
environment rather than the polygon environment because grids use a
smaller amount of storage space and process much faster than polygon
coverages.
From the classified satellite land cover map, each different habitat
type was converted into a separate grid. Examples of the habitat
grids are:
Forest - solid/interior, linear, and mixed with cedar
Grass - tall and short grass, where differentiated
Agriculture
Urban
Water bodies
Stream corridors
We also incorporated coverages of the roads, rivers, and streams in
the study area. Each of these original arc files was converted into a
grid for use with the models as well. We also identified certain
elements of each vegetation class which might be important for
wildlife habitat. For example, many species are affected (both
positively and negatively) by habitat edges. In order to identify a
forest-grassland edge, we started with the upland forest grid and the
upland grassland grid. All habitat grids were reclassified into
binary grids from the original vegetation grid. In each of these
grids, cells of the desired habitat type were identified with a value
of 1; all other cells were identified as 0. Beginning with these
single habitat type grids, we then used the EXPAND function to extend
the boundary of each habitat type. We added these two expanded grids
together; adding the upland forest expanded grid and the upland
grassland expanded grid resulted in cells with three values (0,1, and
2). We then reclassified the resulting grid so that cells with the
value of 2 became a value of 1 and all other cells were reclassified
to 0. This grid now represented an upland forest-grassland ecotone of
30 meters. Similar functions can be used to identify, for example,
interior habitat areas, and thus mitigate any edge effect, and also
to identify habitat areas of a certain size, of concern for species
with minimum area requirements. Each species model involves a simple
additive process and can be developed by including any pertinent
habitat parameters. To allow the development of these models, all of
the possible habitat variables have been converted into binary grids,
with the desired habitat element in each grid having a 1 value and
all other grid cells having a 0 value.
We have also included an assessment of the landscape from an
individual species' perspective. In other words, we have attempted to
view the landscape as one of the modeled vertebrate species might. We
used MoFWIS to identify average home range sizes for as many species
as possible. Based on the wide variety of home ranges, we identified
5 major levels of home range size: 120, 420, 840, 2010, and 5010 m.
(This is the value for one dimension of the home range. The actual
area of the home range is this value, squared.) We generated four
grids for each of these home range sizes. Each of the four generated
grids was offset one-half the distance of one side of the home range.
For example, the origin of grid 120a was at (0,0); grid 120b, (-60,
0); grid 120c, (-60, -60); and grid 120d, (0,-60). These empty grids
were generated in Arc, and then each was converted into a grid, with
a resolution of 30 m.
We used these overlapping home range units with the additive species
model described above. After developing the model for a species,
which involved adding several different habitat grids, we then
performed a ZONALMEAN in Grid on the resultant model, for each of the
four home range grids (a, b, c, and d). These four grids were then
added together for a cumulative grid; this grid was then divided by
4, to obtain a new grid with an average value for each cell. These
values were typically very small, and thus, before converting the
floating point grid into an integer grid, we multiplied the average
grid by 100, in order to retain the significance of the values. This
final grid for each species has a variety of values representing
habitat of differing suitability for the species under consideration.
Higher cell values represent areas of higher suitability relative to
areas with lower cell values. By using this modeling approach, we
have been able to produce refined maps of potentially suitable
habitat with rankings illustrating relative measures of
suitability.
We intend to perform the habitat modeling with both the standard Gap
Analysis procedure, and with the additional GIS operations described
above. We will then assess results from the two types of models to
determine if the additional grid analyses provide significant
information about predicted wildlife distribution and enhance the
standard Gap Analysis.
References
Bridgewater, P. B. 1993. Landscape ecology, geographic
information systems and nature conservation. Pages 23-36
in R. Haines-Young, D. R. Green, and S. Cousins, eds.
Landscape Ecology and Geographic Information Systems. Taylor and
Francis. Philadelphia. 288 pp.
Csuti, B. 1993. Methods for developing terrestrial vertebrate
distribution maps for gap analysis (Data Layers). Pages 2.1-2.52
in A Handbook for Gap Analysis. National Biological
Survey Gap Analysis Program, Version 1. USFWS, Idaho Cooperative Fish
and Wildlife Research Unit, University of ID.
McNeely, J. A., K. R. Miller, W. V. Reid, R. A. Mittermeier, and T.
B. Werner. 1990. Conserving the World's Biological Diversity.
International Union for Conservation of Nature and Natural Resources,
World Resources Institute, Conservation International, World Wildlife
Fund - US and The World Bank. Gland, Switzerland. 193 pp.
Scott, J. M., F. Davis, B. Csuti, R. Noss, B. Butterfield, C. Groves,
H. Anderson, S. Caicco, F. D'Erchia, T. C. Edwards, Jr., J. Ullman,
and R. G. Wright. 1993. Wildl. Mon. 57(123):1-41.
Author Information
Kelly L. Wetteroff
Graduate Research Assistant
School of Natural Resources - Division of Fisheries &
Wildlife
University of Missouri
20 Stewart Hall
Columbia Missouri, 65211
phone: 573-882-1404
fax: 573-884-4239
c653107@showme.missouri.edu
Timothy L. Haithcoat
Senior Research Specialist
Department of Geography / Geographic Resources Center
16 Stewart Hall
phone: 573-882-1404
fax: 573-884-4239
grctlh@showme.missouri.edu
Ronald D. Drobney
Cooperative Fish and Wildlife Research Unit
112 Stephens Hall
phone: 573-882-3436
