Tracy L. Emery, Timothy L. Haithcoat, and Ronald D. Drobney
CREATING AND EVALUATING A FRAMEWORK FOR LAND COVER GENERALIZATION IN MISSOURI
National Gap Analysis protocol calls for land cover at a scale of 1/100000 with a minimum mapping unit of 100 hectares. This scale is not appropriate for the types of detailed studies occurring at the sub-state level for which the databases will be utilized. As a result, it was determined that Missouri land cover would be created at a larger scale than that required for Gap Analysis reporting, and that this land cover would be generalized for GAP reporting and use at the national level.
The challenge this decision poses is the development of a methodology for the generalization of land cover that maintains a level of detail appropriate for the modeling of vertebrate species habitat relationships (modeling that may occur at the national level). Unfortunately, the problems of generalizing and maintaining detail are not adequately addressed by existing methodologies. Current algorithms rely on the combination and simplification of polygons and the elimination of attribute information for those polygons assimilated. This results in a database that has been spatially generalized, and quality compromised. This research purposes to evaluate and conduct spatial generalization with the preservation of the attribute detail. Generalization will be approached as a method for the compression of spatial data, the spatial presentation of the data will be simplified, but the complexity of the attribute information will not change.
Though the stated outcome of this land cover generalization process is somewhat different than traditional generalization outcomes, the previously established principles of generalization still apply. These principles will provide the basis for this generalization methodology.
There are three distinct steps to developing a generalization methodology. The first step is the development of a conceptual framework. This framework gives structure to the process, and assures that the generalization procedure will be approached in a systematic manner with some known goal as the endpoint. In the second step, the actual generalization procedure will be developed. The procedure is the specific approach that will be taken, based on the specific goal or outcome, not the specific generalization rules. With a conceptual framework and an approach to the problem in place, the final step is pooling and then culling expert knowledge into a coded set of rules that will drive the actual generalization.
The development of a conceptual framework
The Brassel and Wiebel model (1988) is a five step approach to automated map generalization. The first step is structure recognition. The objects in the dataset that need to be generalized are identified. Their spatial relationships and relative importance are also studied. The next step is process delineation. Before generalization can occur the specific methodology that will yield the desired output must be outlined. Questions necessary at this stage include: Will the data be transformed? How will this occur? What types of conflicts may occur? And what information will be part of the final dataset? With these decisions made we enter the third step: process modeling. Here, rules and procedures for the generalization are compiled. These rules and procedures will be applied to the methodology developed in the process delineation step. At this point the information that needs to be generalized has been identified, a methodology has been developed that yields a desired output, and the rules necessary to implement the methodology are in place. Generalization, the fourth step, now occurs. The final step is to display the outcome of the process. It is important to note that the final data display had been determined within step two, the process delineation stage.
The development of generalization procedures
The specific procedures used in the application of generalization to the GAP datasets have their roots in geographic information abstraction, because the intent is to preserve the highest possible level of detail during the generalization process. Geographic information abstractions have been defined as '"'constructs that use both definitions and geographical relationships in order to develop the conceptual content of databases'"' (Nyerges, 1991). Abstraction focuses on the suppression of detail, instead of the elimination of detail. This makes abstraction a more robust method of managing data. However, most work in this field has been done in the realm of cartographic generalization, both manual and digital. Though specific answers to the problems of effective generalization cannot be gleaned from these sources, they do provide a valuable foundation for the discussion of generalization.
The pooling and culling of expert knowledge
Digital generalization requires that the artistic side of generalization be turned into a science with clear definitions and known implications of decisions. The difficulty lies in gathering the information and making the rules that will create a replicable and defensible process that can then be applied within real world applications with a high level of confidence. There are three factors to overcome in developing rules that will guide generalization.
First, the artistic nature of manual generalization does not lend itself to rule formation. Because of the subjective and holistic nature of manual generalization, the manual process never developed a set of concrete rules (or even a step by step procedure) that could be effectively replicated. This makes automating generalization very difficult, as computer processes tend to rely on binary (either yes/no, or true/false) questions. The first step towards digital generalization, therefore, is the development of a systematic approach to the creation of decision rules for the generalization algorithm. The approach is a general process, whereas the decision rules are specific to the problem being solved. This subjective process has not, and perhaps can not, be dissolved into a set of rules. Secondly, rules are specific to the purpose for which they are written. It may be impossible to consistently apply a rule, even within a database because of changes made as the data is generalized. A corollary difficulty is knowing when a rule no longer applies. Finally, very slight differences in the relationships among objects may call for a different rule. The accuracy of the rule writing and the proper application of the rules will determine the overall effectiveness of the process and applicability of the resultant map.
Levin (1992) stated that '"'the objective of the model should be to ask how much detail can be ignored without producing results that contradict specific sets of observations, on particular scales of interest.'"' For this project, the focus will be on generalizing (modeling) the land cover. Expert knowledge applies not only to the processes that will occur in the generalization, but also to the expert knowledge concerning the data to be generalized. Central to the generalization of the land cover will be the development of relationships between land cover types. This is based on many factors, including the morphology, physiology, and function of the plants as well as their interrelationships with wildlife habitat. These decisions will effect not only the generalization, but the results of any species/habitat modeling done at the national level with these data. Regardless of how good the generalization methodology is, if there are flaws in the data or models the results of the entire project will be suspect.
References
Brassel, Kurt E. and R. Weibel. 1988. A Review and Conceptual Framework for Automated Map Generalization. International Journal of Geographic Information Systems, 2(3):229-244.
Levin, Simon A. 1992. The Problem of Pattern and Scale in Ecology. Ecology, 73(6):1943-1967.
Nyerges, Timothy L. 1991. Representing Geographical Meaning. in Buttenfield, B. P. and McMaster, R. B. (eds) Map Generalization: Making Rules for Knowledge Presentation, Longman, London 59-85.
Author Information
Tracy L. Emery
Graduate Research Assistant
Department of Geography / Geographic Resources Center
University of Missouri
20 Stewart Hall
Columbia Missouri, 65211
phone: 573-882-1404
fax: 573-884-4239
c548975@showme.missouri.edu
Senior Research Specialist
16 Stewart Hall
phone: 573-882-1404
fax: 573-884-4239
grctlh@showme.missouri.edu
Ronald D. Drobney
Cooperative Fish and Wildlife Research Unit
112 Stephens Hall
phone: 573-882-3436
