Douglas R. Morgenthaler and Timothy L. Haithcoat
Developing an ArcTool for Landform Classification Modeling
Abstract
The objective of this research is the design of a semi-automated classification mechanism for landforms based on user-defined parameters set in a qualitative and quantitative manner through a simplified user interface. The basis for the calculations of land form will be a digital elevation model. Validity of the modeling techniques will be assessed through comparison against landforms delineated on 7.5 minute quadrangles by experts.
This project has created a potentially powerful tool that, coupled with other spatial datasets, can more 'accurately' categorize and classify landforms, serving as a tool for landslide evaluation, soil movement, or watershed analysis. These user-defined parameters will be placed within an ArcTool, providing the user with the flexibility to control automation of the classification process.
Statement of Problem and Objectives
Landform accuracy is difficult to define across a continuous surface. It is only when it is artificially categorized into a set of features that an assessment can be made. The result is a set of user-controlled breaks within and on a continuous surface. Attempts to successfully classify landforms and their characteristics are often subjective, largely based upon the interpreter's background, experience, and current application. In recent years, due to the staggering increase in elevation data types and surface modeling tools, the need for raster-based landform classification models have become more apparent. Most research concerning landform classification has taken place at the conceptual level (Dikau 1990, Evans 1980, Zevenbergen & Thorne 1987). While efforts toward more standardized classifications are underway (Schmid-McGibbon 1993), classification discrepancies still exist, illustrating the need for a more'comprehensive' landform modeling protocol.
The objective of this research is the design of a semi-automated classification mechanism for landforms based on user-defined parameters set in a qualitative and quantitative manner through a simplified user interface. Successful creation of landform breaks will include the quantification and determination of the effectiveness of slope, aspect, and profile and planar curvature to classify geomorphologic units. A second objective of this research is to examine expert landform delineations by application class to determine similarity of landform process by application group. Groups from which participation is sought include: hydrologists, geologists, ecologists, and soil scientists.
Methods and Procedures
The initial step in model development will be the determination of digital source data to be utilized as the basis for model development. We will be using parameters evaluated on 1:24,000 scale datasets in order to determine the optimal output for the classification model. It is the goal of this research to integrate classification schemes advanced into the landform model, and through further analysis expand upon them. The developed model will draw on concepts set forth by several experts within geomorphologic modeling. Dalrymple et al. (1968) developed the idea of using a nine-element matrix incorporating all possible slope and curvature combinations to describe landform. This matrix forms the basis for initial parameter delineation to be implemented. The interface will be written in Esri's Arc Macro Language (AML) to successfully migrate the developed models into an ArcTool. The parameters to be evaluated and implemented in the landform model include: slope, aspect, planform curvature, and profile curvature. Quantitative values for each slope classifier will initially be determined using suggested ranges of degree slope provided by Dalrymple et al (1968). These quantitative ranges, describing qualitative parameters, will be incorporated within a flexible user-based matrix for user control of the classification process.
Analysis, adjustment, and categorization of the model will be based upon validation performed in several phases. First, a map of the Lewis Hollow quadrangle in south central Missouri will be provided to a number of experts in landform analysis, including the application areas of ecology, geology, hydrology, and soil science. Each expert will be asked to delineate landform features given certain mapping criteria for a selected 9 square mile area. The study area was selected because of terrain complexity and availability of digital data. Some experts from each application area will be identified who reside outside of the state and will be asked to participate in order to minimize any local influences. A modified classification scheme after Dalrymple et al. (1968) is to be implemented, comprised of six classifiers of slope: crest, shoulder, fall face, midslope, footslope, and toeslope (Figure 1). The minimum area to be mapped is 10 acres, addressing both maintainance of relief and limitations of the digital datasets to be used. To reduce possible error introduced in synthesizing slope and curvature information, delineation of these attributes will be performed separately, resulting in separate maps illustrating profile and planform curvature. These maps will be entered into a spatial database and coregistered for further analysis.
Another initial phase will be implemented in order to quantify the selected parameters to be used in classifying landform. This will lead to the creation of a modified ArcInfo classification model. This will be accomplished in part by utilizing ArcInfo's CURVATURE function. This, in combination with slope and aspect, will provide the basis for the initial classification output (Figure 2). As a result of the user's inability to adjust the parameter breaks within CURVATURE, several modified classifications will be derived from the original surface grid (Figure 2). A number of landform modifiers will be performed on the original surface, including the use of high and low pass filters, the inclusion/exclusion of ridges and stream network information, using alternate methods for obtaining slope and aspect measurements, and hydrologic iteration adjustments in TOPOGRID, creating a series of potential surfaces on which to obtain measures. These modified classifications will provide the alternatives for categorizing a particular application group to attain enhanced classification correlation in successive phases of the research (Figure 3).
For each iteration within this phase of the classification process, a summary classification from within each application group will be developed. Expert class delineations from similar application areas will be examined to determine areas of fuzziness and degree of agreement within the application area. If a significant correlation is made between experts within a application group, a summary classification will be used to assess the appropriateness of the model against the series of modified input surfaces. If there is poor correlation between the experts, each will be assessed individually against the classification model. If these conditions are met, each groups' collective classification will be analyzed in relation to the classification resulting from the ArcInfo process.
A walkthrough of the process to be implemented follows. In the first iteration (Figure 3a) each of the aggregated application maps delineated by experts will be compared to the original ArcInfo classification. If there proves to be sufficient correlation between these classifications, no changes will be made in the ArcInfo model. However, if significant correlation does not exist between the classifications, the application group classification will be tested against each of the modified ArcInfo model classifications to determine which modifiers or combination of modifiers produce acceptable agreement. Successive iterations (Figure 3b) will first compare the summary classification of each group against previous groups' classification. If there is significant correlation between the two groups, each group will utilize the same model classification. If correlation does not exist, the summary classification will be run against each of the modified ArcInfo models to determine its proper set of modifiers.
Finally an expert classification will be aggregated, resulting in a summary classification across application area and discipline (Figure 4). This summary classification will be compared against the original ArcInfo model to determine its applicability as a default classification model. If sufficient agreement cannot be reached, the summary classification is compared against each of the modified ArcInfo models to determine the greatest degree of agreement.
A comparison between classification methods will be made in order to determine the error distribution in space of the model in classifying landform features. Statistical measures will be made to determine significance and correlation between each of the delineated maps. Based upon the validation results, further adjustments in the model will be made to reflect greater validity for specific application-based landform modeling if possible.
Bibliography
Dalrymple, J., Long, R., and Conacher,A. (1968) A hypothetical nine-unit land- surface model. In Zeitschrift fur Geomorphologie 12: 60-76.
Dikau, Richard. (1990) Digital relief models in landform analysis. In GIS: Three Dimensional Applications in Geographic Information Systems ed. J. Raper, 51-77.
Dikau, Richard. (1990) Geomorphic landform modeling based on hierarchy theory. In4th International Symposium on Spatial Data Handling, July 23-27, Zurich, 230-239.
Evans, Ian. (1980) An integrated system of terrain analysis and slope mapping. In Zeitschrift fur Geomorphologie 36: 274-295.
Jenson, Susan, and Domingue, J. (1988) Extracting topographic structure from digital elevation data for geographic information system analysis. In Photogrammetric Engineering and Remote Sensing 54: 1593-1600.
Schmid-McGibbon, Geshe. (1993) Landform mapping, analysis, and classification using digital terrain models. Unpublished PhD thesis. University of Alberta.
Zeverbergen, Lyle, and Thorne, C. (1987) Quantitative analysis of land surface topography. In Earth Surface Processes and Landforms 12: 47-56.
Douglas Morgenthaler
Head Research Assistant
20 Stewart Hall
University of Missouri-Columbia
Phone: (573) 882-1404
Fax: (573)884=4239
Email: c572853@showme.missouri.edu
Timothy Haithcoat
Sr. Research Specialist
18 Stewart Hall
Phone: (573) 882-2324
Fax: (573)884=4239
Email: grctlh@showme.missouri.edu
