Zhu Zesheng , Sun Ling
A GIS(ArcView)-based model was employed to determine the decisions of optimal fertilization within fields, as well as the optimal locations of fertilization. These decisions were based on some key factors such as soil type, field nutrient level, yield, crop, variety and climate zones. One simulation model was used to design and implement an ArcView-based management system for farm scientific fertilization. The objective of the system design and implementation was to maximize net returns from fertilizer application. ArcView provides the necessary customization and language environment tools in an easy framework for implementing this objective. This ArcView-based fertilization management system can complete many-tasks: create various thematic maps, determining various spatially selective fertilization management decisions, performing the relevant simulation and printing various maps, graphs and tables. A layered model is especially suitable to design and implementation of ArcView-based application system, which was used to determine the fertilization management system architecture. This layered mode approach was proved to be a practical method of designing and implementing a GIS-based fertilization management system, and should be widely applicable to the design and implementation of other similar system.
Currently, most SVF plans are based on spatially positioning and field operations. As a result, they kept simple and rarely include powerful spatial information analysis and processing. In making such plans, simple methods for processing maps are being used by most farmers. In making more suitable SVF plans for their own situation, farmers should have more insight into the potential impact of various alternatives on the results of their field fertilization and should therefore have powerful GIS tools to generate alternative strategies for SVF. In fact, SVF alternatives tend to be planned spatially. Extensive and complex spatial analyses are required to determine the effects of alternatives on SVF. These SVF plans may be improved when the simple methods are replaced by GIS-based ones for SVF decision support. This article describes a possible method and system based on GIS in planning SVF. Next, a GIS-based simulation model developed for planning SVF is described. The model uses a powerful GIS tool-ArcView[2] to simulate and analyze SVF problems. Application of the ArcView- based approach has proved to be successful for SVF decision support systems. The focus of this study is to develop a management system for farm scientific fertilization. Specific objectives are to develop an ArcView-based application software for SVF to verify its successful application with ArcView, and investigate the feasibility of precision farming based on GIS.
An intensive SVF model most relies on a field information system that is similar to GIS such as ArcView. Geographic information system(GIS) is a computer-based system designed to store, analyze and display spatially referenced data and has emerged as an useful tool for natural resource management and graphic processing. Thus, the most important feature of GIS is its excellent ability to process, store and analyze the spatial information. Otherwise, GIS is usually used as a general tool or framework for integrating many other commercial software packages to build more complex and efficient application systems about graphic and data processing. Thus, this model can consider the local needs of the crop-soil-fertilization system in GIS environment. The collected field data about soil nutrient variability are stored as a set of layered data (or themes) in GIS and processed by this model. These data are as the followings:
(i)Crop yield: Determination or detection of local yield makes it possible to establish a balance relation or function between nutrient supply and nutrient uptake.
(ii)Local soil sampling: The analysis of these soil samples yields a mean current nutrient level for the field from which the soil sample was taken.
Usually, there are two types of yield measurement methods, including position detection with the Global Positioning System(GPS) and yield data acquisition. The data evaluation with GIS leads to yield mapping or maps as the above model input. A yield map provides an overall view of in-field spatial variability. It describes the complex effects of various spatially variable factors on a crop, such as soil type and moisture, nutrient availability, drainage status, weed infestation, weather and crop growth. Thus, the variation in yield represents the integrated effects of spatial variability in soil, climate and crop variables on crop. Yield maps can be presented in contour shape, and yield classes can be formed in relative numbers. For example, all yield maps were prepared as contour graphics with yield class widths of 2 t/ha[5]. The measured yields are displayed as raster and contour graphics in a GIS. In raster graphic, its grid sizes must be enough small to lead to higher resolutions of field operation. In contour graphic, the yield class width must be considered in order to allow a clear class assignment. In general, Yield maps are created from the positioning and yield data. Yield variations can be represented clearly by raster graphic and by contour graphic in a GIS. Areas with equal yields and soil properties show that they have equal uptake, so that they must be treated as areas of uniform soil properties at the soil sampling stage. Auernhammer discussed a similar problem[6].
The basic principle of soil nutrient sampling and mapping method using GPS has been discussed by Delcoourt et al.[7]. The variability of soil properties within a field has been recognized. In general, farmers dealt with field heterogeneity by taking soil samples from different nutrient areas. Then, the analysis of these soil samples provides the data about a mean nutrient level for these areas and a mean fertilizer advice for farmers. There are three approaches to soil sampling and analysis. The first approach is called land register approach. This approach requires that the field is partitioned into smaller part with the help of a priori knowledge. Thus, it may have a minimal number of soil samples. The second approach defines the sampling areas starting from yield maps over several seasons. The yield maps can give the consistent yield patterns with time for soil sampling and field partitioning. Thus, a model based on the analysis of soil sampling results and the following yield data can give the optimal value for the required fertilization. Usually, data from the following yield data are used to increase the fertilization precision. The last approach is based on the geographically detailed knowledge of the topsoil nutrient status or type for the entire field, which is called detailed soil survey approach. In the first mentioned two approaches, indirect information from the field is used to define soil sampling or fertilization areas. However, for obtaining complete data about the spatial variability of the fertility levels, the soil samples must be taken in a rectangular grid way[8] over the entire field. Fertilization areas can then be derived from the detailed soil nutrient maps. In our model, the yield maps and soil nutrient maps are used for providing fertilization decision for farmers.
How to represent or describe a fertilization model in GIS is a very difficult problem. However, a method of combining themes and equations can be used to solve this problem. Theme is an important concept of ArcView. In an ArcView, a map is usually related to a project. A project is really a collection of views, tables and other documents. Further, a view is an ArcView document that displays a map and its legend. For example, a view is made up of layers of field information for a particular geographic area. Each layer of field information is a collection of field features such as crops, fertilizer, soil, yield, rivers, roads, boundaries and counties. These layers are called themes. The legend lists symbols representing features of these themes. Thus, a theme is a collection of field features in a view. All the features in one theme are represented by the same type of shape, such as points, lines or areas. Themes also reference the attributes or characteristics of field, yield and soil nutrient level.
The model of fertilization within a field can be represented simply as the following.
T(FA)=T(FN)*Op1+T(FP)*Op2+T(FK)*Op3+T(FY)*Op4
Where
T(FA): Fertilizer application theme,
T(FN): N distribution theme in a field,
T(FP): P distribution theme in a field,
T(FK): K distribution theme in a field,
T(FY): Yield distribution theme in a field,
Op1: N function to compute N economic contents in a field,
Op2: P function to compute P economic contents in a field,
Op3: K function to compute K economic contents in a field,
Op4: Yield function to compute the effect of yield in a field on N, P and K,
+: Overlay- operation in ArcView,
*: Operation that completes input data and output data between theme and its function.
The above equation means that for any crop, operations Opi(i=1,...,4) with themes T(FN) to T(FY) determine economic or optimal fertilization theme T(FA) of the crop.
An architecture of SFMS can be described by a seven-layer architecture model shown in Fig. 1. In summary, simple function of various layers can be discussed as the followings. The layer of field layer describes the geographic position, shapes and characteristics of managed fields. The soil layer describes all information about soils of these fields, which includes data from a detailed soil survey. The main task of climate layer is to collect and generate a number of basic climate data for supporting decision in its high layer. The nutrient layer is used to represent current nutrient levels of these fields.
In the crop layer, a number of data to represent growth of current crops are used to describe crop
status. The yield layer consists of a number of basic yield data to generate various yield maps. The
fertilization layer is used to generate various different fertilization and soil sampling decisions for
different fields or areas according to practical requirement of these fields and with the help of various
basic services provided by its lower layers. In the layered architecture, the lower layer provides
always its service for its higher layer, the higher layer uses the service from its lower layer. To
construct the layered architecture model is a very effective method for designing and implementing a
high quality ArcView-based application system.
The partial source codes of SFMS are written in modular form using the macro programming language Avenue of ArcView 2.1. Each unique procedure or activity is written as a separate script. Totally, SFMS includes more than 60 scripts. Table.1 shows a list of SFMS' scripts.
SFMS.About.JaasSVF
SFMS.Add.GlobalVariables
SFMS.AddTheme.Choice
SFMS.AddTheme.Crop
SFMS.AddTheme.Fertilization
SFMS.AddTheme.Soil
SFMS.AddTheme.WeatherZones
SFMS.AddTheme.Yield
SFMS.Calculate. Fertilization
SFMS.Change.SFMS.Soil.fle
SFMS.Change.Sim.File.FoRecords
SFMS.Change.Sim.File.ForView
SFMS.ChangeTheme.Choice
SFMS.Create.ModelDictionary
SFMS.Delete.Documents
SFMS.Delete.Tablefiles
SFMS.HasVisibleThemes.Update
SFMS.Join.Semiautomatic
SFMS.Join.Simulation.Results
SFMS.Label.VisibleTheme
SFMS.Layout.Create
SFMS.Map.New
SFMS.Map.Open
SFMS.Theme.Properties
SFMS.View.ConvertToShapefile
SFMS.View.Run.Simulation
Table.1: A list of Partial SFMS' scripts
ArcView provides the necessary customization and language environment tools in an easy framework. The framework provides some functions as the followings.
(i)To create the graphical user interface according to user requirements,
(ii)To establish some initial properties for graphical controls to support interaction between user and these controls,
(iii)To write Avenue codes that satisfy the requirement of user interface and simulation model,
(iv)To link scripts written in Avenue to events,
(v)To integrate the framework with other language modules.
Avenue is an object-oriented scripting language. The key point in Avenue is on identifying objects and then sending requests them to complete various complex operations. An object can be considered as a package that is composed of tightly-coupled data and functionality. In Avenue, a request can be sent to an object. When an object receives this request, it performs some relevant action or operation. In ArcView, objects are members of a class hierarchy or architecture. Further, these members can be organized into functional categories related to all aspects of the fertilization application.
Avenue's statements are used to organize and determine when and how requests are made. A request specifies what an instance of a given class will do and a method specifies how it is done. By sending a request to an object, a method appropriate to the class of which the object is an instance is activated. An object in Avenue always responds to a request by returning an object; in some cases, the request creates a new object or returns an existing object.
A prototype system has been used to analyze and process a number of collected data from fields. Fertilizer application with SFMS was compared with traditional none-spatially selective fertilization. When the traditional approach was completed with the fertilization operation, the fertilization efficiency of the traditional approach is not satisfactory due to its none-spatially selective operation. The SFMS-based approach may provide an objective method for performing field nutrient level assessments and making fertilization recommendations that maximize yield or profit. The profit of SFMS-based fertilization approach increased about 10-15% by comparison with the above traditional approach.
These successes show that the shift from non-spatially selective fertilization to GIS-based spatially selective one is a profound advance in research of management system for farm scientific fertilization. Further, some major steps of the method application are as the followings: scooping of an application development project, in which the project area, requirement and relevant variables are defined by the application plan objective, based on the user requirement of spatially selective fertilization management system and GIS(ArcView) environment; collecting data relevant to the model of spatially selective fertilization in the application field, in which these data must be represented as a layered architecture model form with GIS thematic or map by the method for designing a layered architecture; developing, evaluating and selecting all important logical relationships or functions between variables of these layers, in which these relationships are used to build a basic framework of GIS-based application system or model; integrating these relationships and data relevant to the model, in which final application system or model is built; refining this system and improving its performance. Currently, the system is being revised to incorporate more decision functions. A new ArcView-based fertilization management system is being developed, which has more powerful GPS function and generate better spatially selective fertilization recommendations for strategic planning of scientific fertilization.
[2]Esri, Introducing ArcView. Environmental Systems Research Institute Ltd., Redlands, CA, 1994, 98pp.
[3]Schueller, J. K. A review and integrating analysis of spatially-variable control of crop production. Fert. Res., 33(1992), 1-34.
[4]Delcourt, H., P. L. Darius and J. D. Baerdemaeker. The spatial variability of some aspects of top soil fertility in two Belgian fields. Computers and Electronics in Agriculture 14(1996): 179-196.
[5]Stott, B. L., Borgelt, S. C. and Sudduth, K. A., Yield determination using an instrumented CLASS combine. American Society of Agricultural Engineers, St. Joseph, Mich., ASAE-paper, 1993, 93-1057.
[6]Auernhammer, H., M Demmel, T. Muhr, J. Rottmeier and Wild, K.. GPS for yield mapping on combines. Comput. Electron. Agric., 11(1994)53-68.
[7]Delcourt, H. and J. De Baerdemaeker. Soil nutrient mapping implications using GPS. Computers and Electronics in Agriculture 11(1994),37-51.
[8]Burgess, T. M. and R. Webster. Optimal interpolation and isarithmic mapping of soil properties, IV. Sampling strategy. J. Soil Sci., 32(1981): 643-659.
[9]Birrell, S. J., K. A. Sudduth and S. C. Borgelt. comparison of sensors and techniques for crop yield mapping. computers and Electronics in Agriculture 14(1996): 215-233.
[10]Ling, S., W. Yanyi, M. Jinfy and C. Yuquan. Design and application of algorithm for estimating rice yield of county. Proc. of RS-based environment monitoring and crop yield estimating, 1991, pp. 63-71, Beijing University press.
[11]Esri, Customizing ArcView with Avenue. Environmental Systems Research Institute, Inc., 1994, USA.
