This paper presents three alternative methods to analyze the spatial and temporal patterns of crime with the goal of dentifying areas with high number of incidents. The first method is to count the number of nearby incidents from each event, the second method is to calculate the mean and standard deviation of time lags between two events, and the third method is to calculate the total distance of nearest events from each incident. With Avenue programming in Arcview and Spatial Analyst, the analysis of "hot spots" is completed for a sample of data from police offense reports. The main conclusion of this paper is that crime hot spots should be defined not only by the geometry of previous events but also by their temporal characteristics.
A crime hot spot is generally defined as an area containing dense clusters
of criminal incidents. Identifications of hotspots helps public safety
institutions allocate resources for crime prevention activities. This geographical
analysis is usually made based on crime pin maps of reported crime events
over a certain period.
The main issue in the traditional method of hot spot analysis is the
lack of time dimension to be explicitly considered (Illinois Criminal Justice
Information Authority, 1993). A hot spot is determined only by the geometry
of previous events. This simple approach may be good enough to analyze
data over a short time period, but to analyze data over a year or longer
period, crime hot spots should be determined not only by the geometrical
aspect of the events but also by their time characteristics.
One common method used to define crime hot spots is to draw circles
from each event and then find the ellipse representing the highest density
of crime, i.e., to measure events per square mile. This method usually
uses a cut-off figure, for example, only the top 25 percent of circles
containing the highest number of incidents are defined as a hot spot. The
result is an ellipse with no direct comparison with the surrounding area.
Defining a crime hot spot is an intuitive process, however, a definition
only based on the number of events is insufficient. This paper discusses
three alternative methods to define crime hot spots. The first method considers
the number of events, the second method involves a temporal dimension measured
by the mean and standard deviation of time lags between two events. The
third method considers the relative distance between events. Assuming the
three aspects of analysis to be complementary in defining crime hot spots,
this paper compares the hot spot maps derived by these three methods.
In the first method, a crime hot spot is defined as the area where the number of nearby incidents is high. The first question in dealing with this definition is how to choose "near" events from each incident. One extreme is when "near" is only for the location of each event itself, therefore every event will be a hot spot. The other extreme is when we take all events, with the result that no hot spot area can be defined.
The basic idea of counting the number of events or measuring event density
in this method is similar to the approach used in the STAC! program (Illinois
Criminal Justice Information Authority, 1993), but it is different in the
approach to deliniate the hot spots. In the STAC! program, the user define
a grid size and then divide the area into this grid. A circle is made on
every node and then the program counts the number of incidents in each
circle. The circles in the top 25% in terms of incident numbers are then
defined as hot circles. These steps are repreated for larger size of grid
to get the second set of hot circles. Combination of the two hot circles
will give an ellipse or the hot spot with greatest number of incidents.
The method used in this paper counts the number of events within a
certain distance from each event and then store this count in that event.
The test uses 2000 feet to represent the size of three- to five-blocks
of an urban area. After the number of surrounding events are counted from
each event, the next step is to use spatial interpolation between events
in order to make a continuous surface showing the relative level of hot
spots in the area. In Avenue, the main part of this method can be written
as follows:
for each frompt in theVTab
fromShape=theVTab.ReturnValue(theShapeField,frompt)
totalEvents=0
for each topt in theVTab
toShape=theVTab.ReturnValue(theShapeField,topt)
theDistance=(FromShape.Distance(toShape))
if (theDistance < 2000) then
totalEvents=1+totalEvents
end
end
end
In the second method, I define a hot spot as an area where the frequency
of crime incidents is high and/or occur on a relatively regular basis.
This can be measured by the mean and standard deviation of the time lag
between two consecutive incidents, in which a low mean represents a high
frequency of crime and low standard deviation means more regular incidents.
As in Method 1, this approach requires us to determine the search distance
from each incident.
In Avenue, the main part of this method can be written as follows:
searchwithin = 2000
' Before time is calculated, we need to sort the events by date
' This will be from DateList, a list of events date
DateList = {}
meanLag=0
' searching the surounding events
if (theDistance <= searchwithin) then
DateList.Add(RawDate)
end
end
EventCount=DateList.Count
if (EventCount > 1) then
DateList.sort(true)
theLoop=EventCount-2
totalLag=0
for each event in 0..theLoop
Event2=Date.Make(DateList.Get(event+1),"yy/MM/dd-hhhh:m")
Event1=Date.Make(DateList.Get(event),"yy/MM/dd-hhhh:m")
theLag=Event2-Event1
theLaginHour=(theLag.AsSeconds)/3600
totalLag=totalLag+theLaginHour
end
meanLag=totalLag/(eventCount-1)
SumofSquare=0
SumofSquare=SumofSquare+((theLaginHour-meanLag)^2)
end
StdDeviation=(SumofSquare/(eventCount-1)).sqrt
end
end
In the third method, I define a crime hot spot as an area where crime
incidences are geographically concentrated. To measure the level of concentration,
I suggest to use total distance from each event to a number of nearest
incidents. To determine how many nearest incidents to be considered, we
can take a small percentage (5 or 10 percent) of total events. The following
Avenue script shows the main part of this method:
numberofNearestEvents=7
'This number is about 5 percent of total events
FromShape=theVTab.ReturnValue(theShapeField,frompt)
totalDistance=0
DistanceList = {}
DistanceList.Add(theDistance)
end
DistanceList.sort(true)
for each theNearest in 0..numberofNearestEvents
totalDistance=totalDistance + DistanceList.Get(theNearest)
end
theVTab.SetValue(totalDistanceField,frompt,totalDistance)
DistanceList.empty
end
The three different methods above are tested with a sample data of 200 events obtained from theCharlotte-Mecklenburg Police Department. The data cover offenses of homicide, rape, robbery, and aggravated assault occurring in downtown Charlotte during the month of July, 1996. The main purpose of doing the test is to find out whether the three methods give different results indicating that crime hot spots should be defined by both spatial and temporal characteristics of previous events. These sample data are taken from a relatively short time period, but if the test shows three different results then we can anticipate similar results if the analysis is made for annual data.
Figure 1, 2a, 2b, and 3 show that the three approaches are overlapping in one area (Figure 4) that is definitely identified as a hot spot by all three methods. The red area shown in these figures is five percent of the total area. Method 1 and 3 show great similarity, but between these two maps and Method 2, there are some differences. With a temporal measure, some areas in the center of the map are identified as hot spot but not by the other two methods. These maps also suggest that areas identified as hot spots by Method 1 and 3 are not necessarily important in terms of Method 2.
These exercises suggest that analyzing spatial and temporal pattern of crime, especially to define crime hot spot, is technically a simple process in Arcview. However, there are several important issues dealing with crime data that should be realized in this process. This analysis uses offense data, therefore a crime hot spot is defined based only on reported incidents. The other issue is data precision, especially for temporal information. There are many cases in which time of incidents can only be reported within a range of time, for example between 8am and 5pm, rather than a specific time.
The author would like to thank Dr. Lyna Wiggins, Rutgers University, for her comments and enormous support for this research and Charlotte-Mecklenburg Police Department, Charlotte, North Carolina which provide data sample of offense report used in this exercise.
Illinois Criminal Justice Information Authority, 1993. Spatial and Temporal Analysis of Crime: User Manual.
Anak Agung Gde Agung
Rutgers University
33 Livingston Avenue, Suite 544
New Brunswick, New Jersey 08901, USA
E-mail: agung@rci.rutgers.edu
