The Interrupted Goode Homolosine map projection is divided into twelve discrete regions that form six interrupted lobes. The northern regions are often presented with some land areas repeated, showing them without interruption. The Interrupted Goode Homolosine projection currently is not supported in Geographic Information System (GIS) software packages such as ArcInfo3. Fortunately, the twelve discrete regions can be formed from instances of the Mollweide and Sinusoidal map projections, which usually are both supported in GIS software packages. Vector and raster data can be projected into the Interrupted Goode Homolosine projection by splitting it into the appropriate Goode's regions, projecting the separate regions according to the appropriate component projection (Mollweide or Sinusoidal) and offsets, and joining the projected regions into one data set. Data can be projected out of the Interrupted Goode Homolosine projection by splitting it according to the twelve Goode's regions, projecting it from each region's component projection (Mollweide or Sinusoidal) to the required output projection, and joining the desired regions.
Kent J. Lethcoe, Systems Analyst
Data Services Branch
Telephone: (605)594-6502
E-mail: lethcoe@edcmail.cr.usgs.gov
Fax: (605)594-6150
Robert W. Klaver, Senior Scientist
Science and Applications Branch
Telephone: (605)594-6067
E-Mail: bklaver@edcmail.cr.usgs.gov
Fax: (605)594-6529
EROS Data Center
Sioux Falls, SD 57198
