Doron Barankin
Driving / Walking routes for daily water-meter breakage repairs
abstract:
Breakages in water-meters is a daily problem which causes a large financial loss to the municipality as it does not receive money for the water supplied during the breakage period. The municipality employs private contractors to carry out repairs. However, sometimes their priorities concerning repairs are different than those of the municipality.
In order to control the order in which repairs are carried out and to do the job more efficiently, an interactive GIS system was developed. This system determines each contractor's driving/walking route, points out possible parking areas and decides a rigid order of repairs.
The system is based on the following data layers :
i) City streets.
ii) Traffic directions (for driving routes).
iii) The faulty meters. (created daily).
Since the system was put in use, the repair time has been reduced by 70%
Introduction
They receive a standard rate for each water meter. Therefore, they prefer working on a cluster of damaged meters rather then dealing with isolated meters which often cause greater loss to the municipality.
The G.I.S. system
i) City streets.
The daily work schedule consists of the following stages:
a) Gathering data on the faulty water meters
In most cases, the municipality initiates the report on a faulty meter, following a comparison of current and past water consumption that shows a drastic reduction in water consumption (or even negative consumption). Residents usually report on faulty meters only when the consumption measurement appears unrealistically high.
b) Creating a daily layer of the faulty water meters.
The new layer is created based on the city addresses layer.
Map 1: layer of faulty water meters
c) Dividing the water meters into clusters.
Each cluster consists of meters of equal repair priority, within geographical proximity.
Map 2: clusters of water meters
d) Determining the repair priority for each cluster.
The determining factor is cost. A cluster of faulty meters that creates the greatest loss from uncollected water dues will receive highest repair priority. Parking possibilities for the repair team are also indicated for each cluster (one or more possibility per cluster).
e) Creating an optimal (shortest distance) route between the stop points.
Map 3: optimal driving route
The route is based on existing data layers of streets and traffic direction (one- way). Traffic density at different hours of the day is not currently included.
f) Creating an optimal walking route for the contractor within each cluster.
Map 4: optimal walking route
g) The routes are distributed to the contractor at the beginning of each day.
Each contractor receives a drive route between the cluster and a walking route within each cluster, which he is required to follow.
The success of this system has resulted in a new agreement between the Municipality and the contractors:
The Municipality is committed to providing the contractors with a daily driving route of up to 5 km.; the contractors deduct 20% from the repair price of each water meter in such a route.
Doron Barankin
GIS Application Manager
Tel-Aviv-Yaffo Municipality
1 Rabin Sq.
Tel-Aviv-Yaffo, Israel
Telephone: (972)-3-5217140
Fax: (972)-3-5217503
E-MAIL:gilo@tel-aviv.gov.il
