SEARCH & RESCUE PLANNING
A GIS Solution
Aerospace and Telecommunications Engineering Support Squadron
Canadian Forces Base Trenton, Astra, Ontario, Canada
July 1997
THE SEARCHMASTER APPLICATION
Introduction
The Aerospace and Telecommunications Engineering Support Squadron (ATESS), based at Canadian Forces Base Trenton (Ontario), recently fielded an ArcView 3.0 based application for use in Canadian Rescue Coordination Centres (RCC). The development team produced a comprehensive suite of scripts to allow the RCC operators to quickly and easily use map data in the prosecution of Search and Rescue (SAR) cases.
Project Background
This project was initiated roughly five years ago when the RCC operators persuaded Air Command that automation would improve their effectiveness and efficiency. They were right. In fact, they were ahead of their time. Five years ago, the available software did not have a great deal of flexibility (it could not be easily modified), and the hardware systems required to run these applications in a dual screen environment were horrendously expensive.
For several years, the project remained in a research mode. The cost of the projected product continued to be extreme and the functionality did not meet user requirements. However, the IT staff at Air Command were able to implement a dedicated WAN using Cisco routers and dedicated digital circuits in a ring topology. This feature is still in use today!
In September 1996, Air Command down-sized and devolved responsibility to other units. The RCC Automation Project was transferred to ATESS. One of the things that became immediately apparent was that the R&D had developed a momentum that was moving it away from the users’ requirements. It was, in some aspects, a solution looking for a problem. Air Command was convinced that the solution would require SunSparc stations running Intergraph software. Air Command was unaware of two very recent developments that would dramatically change the feasibility of the project: ArcView 3.0 and Windows NT dual screen capability. The project team went to work and quickly came up with a much less expensive solution that would meet more of the users requirements without customizations using exclusively "Off the Shelf" software and hardware. With only minor modifications we were able to create the 80% solution.
After close discussions with the user community, the team began to understand exactly what the users were looking for. Although an excellent Statement of Requirement (SOR) existed, we found that there is no substitute for close dialogue with the user community. We adopted the motto "Build what they want, not only what they have specified." The next step was to establish a test-bed facility at ATESS to provide a development platform, proving ground and training facility.
The team also decided to approach the project in two phases; the first would place LAN’s in five locations complete with a suite of office automation software and a basic GIS and Case Management tool. Phase II would add links between the GIS and case management tool, diversified data resources (such as Jane’s, ship registries, police, fire, ambulance, et cetera), resource tracking capabilities (plotting moving aircraft), Computer Telephony Integration (CTI), and improved WAN services.
Environment
The test bed consists of six workstations, two servers, one colour plotter and one colour laser. The Network Operating System is NT 4.0.
The workstations are Pentium Pro 200's with 64Meg RAM, two 3.2 Gig hard drives, one 21" Monitor, one 17" monitor, and Matrox Millenium graphics cards (with 4Meg RAM). The operating system is Windows NT 4.0 which provides an easy solution for dual screen display (actually one virtual screen split into two monitors). This is an important requirement for the users since they like to work with a map on one screen and utilities on the other.
We chose to use two servers (Primary and Secondary Domain) to improve performance, provide redundancy and increase data storage capacity. These servers are also Pentium Pro 200's with 64Meg RAM, two 3.2 Gig hard drives, one 17" monitor, and one Matrox Millenium graphics cards (with 4Meg RAM). In addition, one of the servers has a SCSI card controlling seven CD ROMs in a separate chassis. This last item provides multiple CD ROMS for the LAN without the high cost of a CD Carousel.
To settle on this hardware configuration, our system engineer, Lieutenant Ashby trialed numerous systems and then put together a small assembly line to build the 40 units required. This allowed us to produce the hardware at half the cost of procuring these systems. A bigger plus was that every single machine was exactly the same.
The Geographic Information System is ArcView 3.0, the data base is Oracle 7.3, and the data base front end application was developed with Power Builder. The workstations also carry MS Office 97, LAN Source WINport, and various other miscellaneous applications.
The LAN’s are protected by a NEC Privatenet firewall and managed by Loran-Plaintree’s "Kinnetics" system.
Development
After analysis of the SOR, careful discussion with the users, and a pinch of common sense, the team concluded that it would be best to develop two basic applications: a GIS that met the users mapping requirements, and a data base system that would manage the case information. One of the criteria used in picking the development tools was that the applications had to be Dynamic Data Exchange (DDE) compliant. In other words, they had to be able to share data. The decided approach was to produce two applications that worked independently, and then in Phase II integrate the two applications together. Once the GIS had been chosen, we hired a brilliant young contractor named Steve Edgett who got to work immediately on implementing the user requirements. At the same time, our PowerBuilder expert, Ms Jackie Collins, was hard at work turning the users’ data entry forms into PowerBuilder digital forms.
In April, after a flurry of last minute requests from the operators, the two major applications were frozen and polished for roll-out. They were named "SearchMaster" and "CaseMaster". They are both currently in use at RCC Trenton, the Canadian Coast Guard College in Sydney Nova Scotia, and Marine Rescue Sub Centres in St-Johns Newfoundland and Quebec City. Systems for RCC Halifax and RCC Victoria will be delivered later this summer.
The military and civilian teams are hard at work on Phase II requirements right now. We expect to roll-out the next version this fall, after the summer silly season ends and the RCC operators get a chance to catch their breath.
Data Sets
From very early on in the project, the users stressed the importance of using raster maps. They were easily persuaded of the flexibility and power of digital maps, but they also required the "lay of the land" that raster maps convey so well. Fortunately, ArcView was able to handle both types of data. Initially, there were some glitches with the Compressed ADRG (CADRG) reader, but Steve Edgett and Kerry Phelps (Esri Redlands California) burned up the phone lines and produced a working utility. The system also uses Digital Chart of the World data as its digital map base. We hope to upgrade the digital data set to Vmap level 0, 1 and 2 (Canadian products) in the near future. For Nautical charts, the application uses NTX charts (also a Canadian product) for which we will have a direct read capability, thanks to ArcView.
As mentioned previously, case information is stored in an Oracle DBMS. In addition to case information, SAR operations make use of a wide variety of data sets including: Canadian Gazetteer, aircraft and vessel registrations, a crash registry, Canada Pro Phone directory listing, SAR resource database, Janes Aircraft, Emergency Locater Transmitter (ELT) Registry, emergency services locations and others. Acquisition and integration of all of this data is complex and still on going.
End Product
We have now completed Phase I and are currently developing Phase II features. The Phase I product was rolled out in April and contains almost all of the user requested functions. It provides Canadian Gazetteer, airports, known crash sites, highways, and many other useful themes. In addition, it provides raster and vector map viewing, a variety of user definable search areas, projection toggling, additional map manipulation utilities and many other features. It must be said that ArcView 3.0 met many of the users’ requirements "right out of the box", thus the 80% solution.
High Lights
Never ask a developer to list the high lights. We’re very proud of our product and it’s difficult to keep the list short.
Adjustable thresholds for active themes: Themes that Automatically disappear when you go above or below user-definable threshold value.
Five different user-definable search areas: The users can plot search areas in an expanding square, a mountainous region "meandering" corridor, a rectangle based on last known position and destination, a polygon and a drag and drop rectangle. These areas are created as themes and come with additional themes revealing secondary search areas and known crash sites in the area.
Raster image overlays
. Simply click on a tool drop down menu, select the scale you want (1:1000K, 1:500K or 1:250), and then click on the area of interest on the map. The raster image appears as a tile, becomes a theme and can be manipulated to the appropriate layer. Click again on the same tile and the image disappears. Click on neighbouring areas and seamless raster images appear there also (as the same theme). This feature gives the users effortless access to the valuable information on the CADRG maps.
What’s Next
The projected product for Phase II will include greater data integration, CTI linked with both CaseMaster and SearchMaster, live on-screen tracking of SAR aircraft, integration with drift calculation applications, display of ELT locations, and live display of Self Location Data Marker Buoys.
Summary
ATESS only recently assumed responsibility for this project. We were able to capitalize on brand new technology to
put affordable systems on the users’ desktops. Using off-the-shelf hardware and software, along with some amazing avenue scripts, the project was able to deliver a product that was energetically accepted by the user community. The second phase will see some highly complex data integration as well as some extremely useful "live" displays of SAR resources, crash locations, and drift marker buoys. The team is currently hard at work at the test-bed facility in Trenton, Ontario.
