To use a digitizer with ArcInfo on a UNIX host, you would normally have to either directly plug the digitizer's cable into a serial port on a UNIX host or purchase a Tektronix X-terminal and connect your digitizer to it and make the digitizer work with ArcInfo on a UNIX host.
Connecting a digitizer directly to a serial port on a UNIX host limits the physical location of the digitizer. You can not place a digitizer away from a UNIX host in more than 20 ft. in most cases. The second connection method overcomes that limitation. You can place the X-terminal anywhere has network connection. But the cost of an X-terminal usually ranges between $4,000 and $8,000.
This software product would save the X-terminal purchase cost and provide the same and sometimes more capabilities. All you need is a regular PC with Windows95 operating system and a TCP/IP network protocol configured correctly. Any X-window emulation software (costs about $50 to $400) will give you a X-window display capability right on your PC screen. Even in places where no network connection is available, WINDIG will give you access to ArcInfo digitizing capability via dial-up ppp networking.
There are 3 components in WINDIG. The first component is a client software "digiconn" running on your PC. (image on left) It will capture the signal generated by pushing a digitizer button and send the signal to a UNIX host through a TCP/IP socket. The second part is a server software "digi_server" running on your UNIX host. It will listen the socket port and once a digitizer signal arrives, save the signal to a FIFO (first-in-first-out) file. The last component is a simple ArcInfo AML (Arc Macro Language) program "pcstat.aml" which allows a GIS user specify the digitizer type and where the ArcInfo "digitize" command should look for the digitizer signal. |
"DigiConn.exe" is a client in the package. The server component is the software named "digi_server". You do not need to do anything for the server component. It is installed by system administration.
The thrid part, an AML program "pcstat.aml" and "dig.menu", has been installed also as an ArcInfo utility in system level atool directory. Again you do not do anything for this part either.
If you are installing the software package for non-DNR GIS system, the complete source code, documentation, and executables can be download from:
The file is self-extracting executable. After WINDIG is unzipped on PC, you should move the server and the AML / MENU components to your UNIX host and install them there.
Follow these installation instructions:
1. It is suggested that you install the server program "digi_server" in /usr/local/bin. Make sure the server program can find "tclsh" on your system by modifying the path in the first line of the server program.
2. Ask your system administrator to designate a TCP/IP socket port for WINDIG and start the server program as a deamon on your host. The default socket port is 2000. If you decide to change the port, edit the "digi_server" program. All client programs have to use the same socket port number to establish communication with the server.
3. Check UNIX system dependency part in the server program. It is documented in the program header in detail.
4. Lastly, install the ArcInfo aml and menu as an ArcInfo utility in system level atool directory for your custom site. There is a system dependency inside "pcstat.aml". For those users who have not upgraded to ArcInfo 7.1.1, you need to replace %USER% in the code with [extract .. [ pathname $USER ] ... ] to get a user's ID on your host.
Now log on the system via X-emulation and start ArcInfo. Run "PCSTAT" Atool command. You will be asked to identify your digitizer model from a short list. After you have done the selection, switch back to Windows95 environment and start "DigiConn.exe" program. The first thing to do is to configure the client program by clicking the configuration icon. The configuration icon is located on the bottom of the graphic user interface of the program and it looks like a digitizer pad.
There are serveral parameters need to be specified:
1. IP address of your host (Do not use the host name);
2. Socket port number (2000 for DNR GIS users);
3. Your User ID on the host;
4. Communication parameters for your digitizer, that includes serial
port, baud rate, data bits, stop bits, and parity.
Once these parameters are specified, they will be saved in Windows95
registry so that they do not to be specified again by the user.
After the configuration, click the green light icon to connect the server. The two display areas on the "DigiConn" main GUI will report the serial port and network connection status to you. After communication is successfully established, you can switch back to ArcInfo session on host and start digitizing.
The server program will also report any changes on communication status to you on host.
Since the server program is running as a deamon on host, you could alternatively run client from PC first and then start ArcInfo on host.
If you run into any errors, plesase check FAQ portion of this help document.
1. What is Tcl/Tk?
2. Where can I get Tcl/Tk and how to install it?
3. How to add more digitizer type?
4. What does the error message X mean and what should
I do to correct the problem?
5. What is MFC40.DLL? Why do I need it to run "DigiConn"?
6. Can I use this product under Microsoft Windows3.11
operating system?
7. I ran ArcInfo "digtest" command and the digitizer
did not work correctly. What is wrong?
8. How can I test the hardware connection between my
PC and digitizer?
Tcl/Tk is a scripting language invented by Dr. John Ousterhout. You can get a full picture of Tcl/Tk by visiting SunScript business unit of Sun Microsystems.
Tcl/Tk can be download from official download site of SunScript. Installation instructions should come with each download package for various platforms.
By editing "dig.menu" file. Refer to ArcInfo help utility "arcdoc" (ArcInfo 7.11) on how to write/modify the ArcInfo menu.
Failed to create communication thread | Report to author. |
Windows sockets initialization failed | Report to author. |
Can't find the server | Problematic TCP/IP configuration; Re-configure. |
DNS server is not working. | Contact your sysadmin. |
Failed to create socket | Report to author. |
Failed to connect to the server | Server is not running on host. Launch server program. |
Failed to send data | Server has been shut down. Launch server program |
Failed to open specified serial port | Possible hardware failure. See FAQ 8. |
The specified user is not logged on the host. | Verify user_id and log on host first |
Failed to receive response from server | Lost network connection. Contact your sysadmin. |
MFC40.DLL is the Microsoft Foundation Class version 4.0 Dynamic Linking Library. It contains the libraries for developing many applications. DigConn Program uses MFC40.DLL so that the DigiConn can be very small and easy to maintain.
6. Can I use WINDIG under Microsoft Windows3.11 operating system?
When you are digitizing and use X-emulation software to view your ArcInfo display, you are multi-tasking. Window3.11 is not a multi-tasking operating system, unfortunately. You can upgrade to either Windows95 or WindowsNT operating system to use WINDIG.
7. I ran ArcInfo "digtest" command and the digitizer did not work correctly. What is wrong?
ArcInfo's digform directory contains conversion files for each digitizer models. Some of the conversion files have conversion string dealing with hardware initialization / shutdown sequences. DigiConn is a software solution for digitizer. It does not need the initialization and shutdown sequence conversion. Ask your system administration to modify the proper digform file (or make a new one) so that no initialization / shutdown sequence conversion string is contained in the digform file. "digtest" should work fine after this is done.
8. How can I test the hardware connection between my PC and digitizer?
There is an accessory in Windows95/NT called HyperTerminal. You can use HyperTerminal to test the hardware connection between your PC and digitizer. Steps of test the connection are described below:
1. Run HyperTerminal program from Accessory folder;
2. Double click Hypertrm icon to launch a new connection;
3. Name your new connection and go to File->Properties;
4. In New Connection Properties window, choose "Direct to comX" in
entry field titled "Connect using:";
5. Press "configure" button directly below the entry field to configure
your com port X;
6. Save your settings for the new connection;
7. Turn on your digitizer and push some buttons. You should see a string
displayed in the HyperTerminal window. If you do not see the string, your
hardware connection has some problems.
I also want to thank Bob Mcgaugghey, Cooperative for Forest Systems
Engineering at University of Washington, who has generously provided ftp
and web hosting for Windig software.
End of Document.
