René Andersen
MIKE INFO Coast - An Extension for Coastal Zone Management
MIKE INFO Coast is a product from the Danish Hydraulic Institute (DHI) specifically designed for the handling of coastal data. It is constructed as an extension to the GIS ArcView 3.0, and it thus has all the benefits of a GIS. Apart from geographical maps, MIKE INFO Coast handles data such as bathymetric surveys, coastal profiles, images (ortho-photos and other photos) and any type of hydrographical and water quality measurements (e.g. wind and BOD data). With MIKE INFO Coast it is possible in a user- friendly manner to manipulate these heterogeneous data relating to a coast in various ways (e.g. calculation of volume changes from survey to survey). Reports and standard presentations for decision support can also be generated easily. MIKE INFO Coast exchanges data with DHI's other software products, such as LITPACK and MIKE 21.
Background
Historically, the Danish Hydraulic Institute (DHI) has focused its computing efforts in the computer simulation area. Thus, since the end of the sixties DHI has developed models of various kinds. Some of the most well-known are MIKE 21 (a modelling system of 2D free surface flows), MOUSE (a modelling system for pipe networks), MIKE 11 (a system for 1D modelling of rivers, channels and irrigation systems) and LITPACK (an integrated modelling system for littoral processes and coastline kinetics).
With the spread of computer technology in the recent years, however, it has become apparent that the task of evaluating model result data is no longer solely the task of the model expert. An explicit need for user-friendly access to complex models and their results has been expressed. In order to accommodate this DHI has developed various interfaces to the models. As all the models of DHI ultimately express geographic information, a GIS (ArcView) has been chosen for the presentation of the model related data. Thus, several modules have been developed as add-ons to the DHI models. E.g. MIKE 11 GIS for MIKE 11, MOUSE GIS for MOUSE. Common to the above mentioned GI-modules are that they require a model to supply data.
 Inspired by the recent EAGLE-project where a GIS-based system was developed for presentation of many different kinds of data (such as hydrographical and biological data, model result data, images etc.) DHI has set out to create a suite of information systems for presentation and management of environmental data. This suite of products has been coined MIKE INFO, and it is the intention to develop MIKE INFO products for various areas of data management. One of these areas is the management of coastal data, and the corresponding product is MIKE INFO Coast.
What is MIKE INFO Coast?
MIKE INFO Coast is a tool for managing coastal data. This covers specifically: MIKE INFO Coast has been built as an extension to the GIS ArcView 3.0 from Esri (Environmental Systems Research Institute). This means MIKE INFO Coast and ArcView are completely integrated, and that all the built-in functionalities in ArcView are available in MIKE INFO Coast. As an example you can use ArcView�s standard facility for digitising maps, and then later on have them presented within MIKE INFO Coast.
In ArcView/MIKE INFO Coast the user interface depends on the current active document, i.e. the user interface changes as the active document changes. ArcView contains several types of documents, which all have their individual user interface. When loading the MIKE INFO Coast extension, you actually load a new type of document into ArcView. This type of document is called �coast�, and has its own tailor-made user interface especially suited to work with coastal zone data. For instance the user interface covers options such as �calculate differences between surveys�, �import sediment size data� and other functions specific to coastal zone data.
 A situation of typical use would be a coast, where bathymetric line surveys are performed regularly to record the depths. After each survey, the recordings will be imported into MIKE INFO Coast and processed. This processing involves organising the survey lines into so-called profiles. These profiles can then be compared from survey to survey, and differences (i.e. changes in the bathymetry) can then be calculated. The screen-dump below shows one such session, where a difference between two surveys has been calculated. Having processed and presented the bathymetric survey data within MIKE INFO Coast a report can be generated and saved for later.
 Difference calculation using MIKE INFO <I>Coast</I>
 Fig 1. Difference calculation using MIKE INFO Coast.
MIKE INFO Coast has been used in-house in several projects (in countries such as the United Arab Emirates, Malaysia and Bangladesh). Typically, a stretch of more than 30 km shoreline are to be maintained. Data as diverse as hydrographical, biological data, images, maps and (of course) survey data has been covered in the projects. The MIKE 21 modelling system has also been applied in some of the cases, and input/output routines between the two products has been implemented. Having developed and tested MIKE INFO Coast for several years in-house, DHI has released the first version - 1.0 - in public (October 1997). In the hour of writing, an update enhancing the facilities of MIKE INFO Coast is planned. It is expected to be released medio 1998.
Data Handled by MIKE INFO Coast
MIKE INFO Coast handles data in the following categories:
Functionalities in MIKE INFO Coast
MIKE INFO Coast covers a range of functionalities that can be used for managing and presenting coastal zone data. Some of these functionalities are listed below:
The functions mentioned so far primarily concern data organised in profiles. However, MIKE INFO Coast does not require this kind of organisation. Other functions are listed below:
MIKE INFO <I>Coast</I> report presenting flooding in cross-section view. The example is from the Bay of Bengal, where flooding as a result of cyclones occur frequently
Fig 2. MIKE INFO Coast report presenting flooding in cross-section view. The example is from the Bay of Bengal, where flooding as a result of cyclones occur frequently.
Conclusion
This paper has briefly described the product MIKE INFO Coast version 1.0 as it has been developed by the Danish Hydraulic Institute. It is the first member of the MIKE INFO family, which is a suite of product that attempts to present data in an easy, informative and user-friendly manner. It has been the aim to construct a system, where the user can move quickly from import of data to reports presenting these data appropriately. It is easy to predict that more systems like this will appear in the future, and DHI has committed itself to make an effort in this development.
References
Andersen, R., 1996. EAGLE - A GIS for Environmental Impact Assessment. Geographical Information. From Research to Application through Cooperation. Vol. 1: 310-317. IOS Press, Amsterdam.
Foster, T.M. and Skou, A.J., 1992. LITPACK, An Integrated Modelling System for Littoral Processes and Coastline Kinetics. 3rd International Software Exhibition for Environmental Science & Engineering. Como, Italy.
Skou, A., Hedegaard, I.B., Fredsøe, J. and Deigaard, R., 1991. Applications of Mathematical Models for Coastal Sediment Transport and Coastline Development. Proceedings of COPEDEC III. Mombasa Kenya.
Warren, I. R. and Bach, H. K., 1992. MIKE 21: A modelling system for estuaries, coastal waters and seas. Environmental Software 7. Elsevier Science Publishers Ltd.
René Andersen
M.Sc., Computer Science, B.Sc., Linguistics
Hydro Informatics Technologies
Agern Allé 5, DK-2900 Hørsholm, Denmark
Phone: (45) 4576 9555.
Fax: (45) 4517 9185.
E-mail: rva@dhi.dk.
Web: www.dhi.dk
