Rod D. Kuhns
April 3, 1998
Strategies for Designing and Building Reusable GIS Application Components
Abstract
This paper presents software engineering strategies for designing and building reusable Geographic Information System (GIS) application software. With proper planning and execution, these methodologies will bring significant cost savings and efficiency gains to one of the most expensive aspects of customizing GIS software tools. Organizations employing contractors to develop software applications, as well as application developers, will both benefit from these methodologies. This paper does not discuss the Microsoft component object model (COM), which Esri will utilize to provide application developers with access to Esri product objects assembled by Esri. The new Esri product direction based on the Microsoft COM paradigm will greatly enhance the third-party application development environment in the future, and it is also consistent with the reuse strategies discussed in this paper.
The paper presents time proven methods and tools for creating, managing, and accessing a library of reusable software components. In addition, cost-benefit guidelines are developed to help an organization decide when the benefits involved in implementing reusable coding procedures outweigh the implementation overhead. Specific recommendations are made for code documentation practices, software design, and management procedures that encourage and result in successful code reuse practices. One of the major challenges of building reusable software in the GIS environment are the high dependencies of the application on a specific "client-dependent" data model. The paper will address how to deal with specific application data dependencies and engineer software components for portability across different data models.
What is Software Component Reuse?
Software component reuse is the software engineering practice of creating new software applications from existing components, rather than designing and building them from scratch. Reusable components can be requirements specifications, design documents, source code, user interfaces, user documentation, or any other items associated with software. All products resulting from the software development life cycle have the potential for reuse.
Business Case for Software Component Reuse
Reusable components are easier to maintain (over time) and typically have a higher quality value (more robust and fewer errors). The practice of component reuse supports the motivation for development of specialized GIS applications. The business case is reduced application development time, reduced application cost, and improved application quality. Assuming the motivation for use and development of specialized GIS application software is one or several of the following:
Then, the easiest way to accomplish these goals includes one or both of the following:
Examples are provided below.
Why are Geographic Information Systems Candidates for Cost Savings from Component Reuse?
Custom applications built in conjunction with geographic information systems are prime candidates for component reuse for the following reasons:
The answer to this question lies in the fact that many businesses will need to perform or contract for the customization efforts and provide a means of reducing or overcoming the complexity of GIS. Cost is the bottom line. Component reuse can significantly reduce the cost and time requirements of GIS implementation regardless of who performs the customization. The greater the amount of customization performed by an organization, the higher the return on investment in reuse practices. Companies, such as Convergent Group, can pass very significant savings on to clients building customized applications due to the shear volume of the specialized application and component library development performed.
How Will GIS Users Obtain Cost Savings from Component Reuse?
Traditionally, GIS product vendors, such as Esri, have excelled in providing "tool boxes" for processing geographic data. Because of the uniqueness of the data sets required in each domain, the tool box approach has traditionally been, and will continue to be, the most successful way to bring "shrink-wrapped," COTS software solutions to the market. COTS software in the GIS market primarily consists of the "toolkit" and not end-user applications. The "shrink-wrap" COTS approach is most suitable for desktop applications, such as word processing, spreadsheet, and communication applications, such as e-mail and Web browsers.
However, GIS tools with many diverse applications are often too complex for users not using the technology on a daily basis. The users of the software tools must acquire, combine, and apply specialized education and knowledge in the use of the tools, along with their knowledge of the particular business domain, to arrive at the desired solution. The difficulty in acquiring and maintaining a diverse knowledge base, coupled with their complexity, has led to the popularity and demand for creating specialized GIS applications focused on a particular business requirement and a unique data model. Thus, the complexity of a GIS tool box is often simplified for a particular use through GIS application development.
It is in these specialized applications where component reuse becomes most beneficial. Rather than developing each unique GIS application from scratch, it is much more cost effective (for both buyers and service providers) if application developers can utilize previously created components. Specialized application development then becomes a lower cost practice of matching similar requirements, finding and assembling the components in a way that provides the solution to a unique requirement.
Another factor driving the industry-wide reuse initiative is simply the volume and complexity of computer information and tools needed to process that information. As more and more corporate information databases continue to be developed, the user community continues to grow, as does the need for increased and widespread spatial analysis tools. At the same time, the complexity, depth, and volume of GIS processing tools continue to grow. It is no longer practical for everyone who can benefit from spatial analysis capabilities to obtain and master the use of the highly specialized GIS software tools.
The demand for intuitive, simple-to-use, yet highly specialized and sophisticated, GIS applications continues to be the challenge facing GIS technology providers today. Again, component reuse offers significant cost reductions and affordable solutions for deployment of customized spatial analysis applications. Deployment of customized GIS tools and capabilities to a user community primarily educated in their own business domain, and not on GIS technology, will continue to be a requirement that promotes reuse practices.
Companies specializing in GIS application development, such as Convergent Group, are finding that component reuse techniques can significantly reduce the development time and costs for clients. Due to component reuse disciplines, companies are now able to contract for or build affordable, easy-to-use GIS applications that are customized around their unique information infrastructure.
By lowering the cost of specialized GIS applications, component reuse indirectly helps deploy GIS to users who cannot afford the luxury of time or money to becoming highly trained and educated in spatial data processing tools.
Software reuse is a relatively new approach in the GIS industry, and, for the most part, it is not yet common practice in this industry today. The software engineering community, as a whole, has adopted reuse and embraces the approach wholeheartedly. The "data centric" nature and relative immaturity of the GIS applications market are reasons the GIS industry has been slow to adopt reuse practices. The rising cost of creating new GIS applications and of extending existing GIS applications is the catalyst motivating the industry towards software reuse consideration.
Software reuse is not a practice that will just happen because it sounds like a good idea. Developing or utilizing reusable components requires an up-front investment, up-front planning, established reuse techniques for building and using the components, effective detailed documentation of the components, and an indexing system or search engine to enhance access to the components for the software development community.
The future of software engineering for economic reasons will become the art of assembling components, rather than the art of building components, as it is today.
Obstacles to Software Reuse
Characteristics Needed for Qualification as a Reusable Component
In order for a component (specification, design, code) to be reusable, it needs to have certain qualities that contribute to its reusability. Reusability is defined as the extent to which a software component can be used with or without changes in multiple software systems, versions, or implementations (McClure 97). A list of those characteristics generally sought after to promote reusability as presented by McClure are as follows:
Guidelines for Creating a Reusable Component
McClure has also provided the software industry with techniques for building reusable components independent of whether or not an object-oriented language is available. This makes the technique applicable to GIS applications development in the entire line of Esri development languages, to include traditional proprietary languages, such as AML or Avenue, as well as the Open Development Environment languages, such as Visual Basic, C++, or TclTk. The techniques for creating components most applicable to reuse, as presented by McClure, are as follows:
The following sections address each of these well-known techniques in the software engineering industry. The techniques are mandatory in the component production process to avoid retrofitting activity for the next developer who attempts to use the component. It is recommended that GIS application developers follow these guidelines to the extent that time and budget allow, regardless if the component being produced is specifically designed and designated a "reusable component" or not. A GIS application will be reused whether or not it was originally intended to be reused. By following these guidelines, applications will be much more "ready" for or have a greater potential for future conversion into a generic reusable component.
Generalization
Generalization is the practice of identifying and designing/building for common uses of a component and removal of special case processing or differences required by various uses of the component. When reused, the generalized component offers a common service to many uses. The reuser of the component is responsible for adding any custom services or specializations back into the component for the particular use. Techniques identified to assist in generalization of a component include the following:
Standardization
Standardization is the practice of developing and following a uniform approach to defining and building each component. GUI interfaces, help systems, coding styles, uniform structured programming techniques, naming conventions for variables and functions, avoiding use of global variables, decomposition into modules that are completely independent, information hiding concepts, and module cohesion need to be defined and enforced. The higher the level of standardization, the easier it will be for component developers and users to find and assemble applicable components for system solutions. A typical standardization checklist is presented below that has been derived from several of the referenced authors, which may be utilized in a formal technical review of an application development assignment:
Automation of Components
Automation refers to having a CASE tool generate some piece of an application, such as a design document or actual code. If the developer can plug in some unique characteristics of a particular requirement, such as a data model, and have another tool automatically generate a component, there are large opportunities for reuse savings.
For example, a custom GIS browser interface based on Map Objects technology is desired by several different users, but the only difference is the list of themes, scale thresholds, symbols, data layer names, and descriptions. Several non-related businesses and agencies have been identified that desire exactly the same functionality for this component of their desktop GIS data access tool. Each user has a separate data model, and manual coding would be required to tailor the interface accordingly in each case. By spending extra up-front time to develop a code generation engine that takes the data model, as an input and automatically generates the complete browser interface, the return on investment can be met with only a few interfaces.
The bigger the component, the better. One of the design decisions in component engineering is how much functionality will be exactly the same in all use scenarios. If a large chunk of functionality can be placed in a single component, then reuse cost savings are maximized. The tendency when designing for reuse is to break the system down to very small, very simplified tasks and assign components to each. If it can be discovered that for every implementation, a large group of tasks can be combined into a single component that will service each implementation equally without specialization, then this represents a tremendous reuse advantage.
Certification of Quality
Creating Reuse Documentation
How to Build Reusable Components
Listed below are several practical guidelines and advice to assist developers in the creation of new reusable components:
Component Repositories
A reuse library or component repository organizes, stores, and manages reusable components, often supporting multiple versions of the components (McClure 97). The primary requirement is assigning and dedicating a staff resource to tend to and manage the repository. A secondary requirement is allowance for developer access to the library in a manner that makes searching for and finding components an easy task. McClure recommends that several tasks be performed in the creation of a repository, including most of the following:
Strategies for Implementing Software Reuse Practices in an Organization
What are the Costs Associated with Software Reuse Practices?
What are the Most Common Organizational Failures when Transitioning to Reuse?
What are the Most Common Technical Failures when Transitioning to Reuse?
References
Coleman, Derek, Arnold, Patrick, Bodoff, Stephanie, Dollin, Chris, Gilchrist, Helena, Hayes, Fiona, and Jeremaed, Paul, Object-Oriented Development: The Fusion Method, Prentice Hall, Englewood Cliffs, NJ, 1994
Coulange, Bernard, Software Reuse, Springer -Verlag, London Limited 1998
Jacobson, Ivar, Object-Oriented Software Engineering: A Use Case Driven Approach, Addison Wesley, Reading, MA, 1992
McClure, Carma, Software Reuse Techniques, Adding Reuse to the Systems Development Process, Prentice Hall, Upper Saddle River, NJ, 1997.
Meyer, B., Object-Oriented Software Construction, Prentice-Hall, Englewood Cliffs, NJ, 1988.
Reifer, Donald J., Practical Software Reuse, John Wiley & Sons Inc., New York, New York, 1997
Sametinger, Dr. Johannes, Software Engineering with Reusable Components, Springer - Verlag, Heidelberg, Berlin, 1997
Center for Computer Systems Engineering Information Clearinghouse (CFCSE-IC)
About the Author
Rod D. Kuhns
Senior Software Engineer
Convergent Group
6200 S. Syracuse Way, Suite 200
Englewood, Colorado 80111
(303) 741-8400
http://www.convergentgroup.com
Email: Rod.Kuhns@cvg-grp.com
