Table 1. The geographic data sets with descriptions and sources for the logistic regression model used to predict the probability of development
Data Description
Geographic Data Set
Source
Random integer grid
RANDOM
Created in GRID TM and masked to include only areas within the parish
Points remained forested or changed to urban (0 or 1 respectively)
CHANGE
Change detection analysis performed in GRID using Stennis Space Center image (1981) and the USGS Southern Science Center image (1993)
Area of contiguous pine or mixed forest cover (ha)
AREA
Polygon coverages created from Stennis Space Center (for 1981) and USGS Southern Science Center (for 1993) satellite images using ArcInfo
Population density by census block
POPDEN
Block locations were obtained TIGER TM 92 line files and changed to a coverage using Arc/Info TM. block areas determined from Arc/Info. STF1A CD from the US Census Bureau provided total population in each block in 1990. St. Tammany Parish Office of Information Services Provided 2003 population estimates by Census Tracts. Population density was calculated using Arc/Info
Euclidean distance from sample point to nearest state of federal highway (km)
ROADS
Federal and state highways identified through Wessex First Street TM. GRID was used to determine Euclidean distances
Euclidean distance to the major access points to New Orleans (km)
ACCESS
Digitized points from the screen guided by the parish roads information obtained from Wessex First Street. GRID was used to determine Euclidean distances
Euclidean distance to interchanges on limited access highways (km)
INTERCHANGE
Interchanges were identified through Wessex First Street. GRID was used to determine Euclidean distances
